[mapguide-users] Possible bug with FDO Provider for MySql
Carmelo Saffioti csaffi at libero.it
Fri Nov 28 05:33:56 EST 2008
I tried the r3481 version too, but the problem still remains...
  ----- Original Message -----
  To: MapGuide Users Mail List
  Sent: Friday, November 28, 2008 11:23 AM
  Subject: Re: [mapguide-users] Possible bug with FDO Provider for MySql
  I'm using the 1.0.9 version. I wasn't able to find the newer version. Where can I find it?
  Cheers
  Carmelo
    Sent: Friday, November 28, 2008 10:49 AM
    It looks like a bug in Maestro.
    Feel free to create a ticket for the problem.
    If you can create something that allows me to reproduce the problem locally, I will try to fix it.
    Are you using 1.0.9 or the newer r3481?
    There was a bugfix for database featuresources that is not in 1.0.9.
Regards, Kenneth Skovhede, GEOGRAF A/S
    Carmelo Saffioti skrev:
      Hi everybody!
      I'm using MapGuide Maestro for creating a data connection to a MySql db. When I add a new Dataconnection with "OSGeo FDO Provider for MySql" everything is ok, in fact if I click on "Test connection" I get: Provider reported no errors... I assigned database, server, port, username and password, but there's nothing about tables...
      The problem is when, after creating a new layer, I try to choose as feature resource the MySql Dataconnection before created. I get the following error message:
      "failed to read schema from data source"
      If I use MapGuide Studio for doing the same things, everything works fine! So, is there anything wrong in what I'm doing or is there any bug in Maestro??
      Thank you very much in advance
      Carmelo
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081128/9edadc0c/attachment.html
