[mapguide-users] Possible bug with FDO Provider for MySql
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Nov 28 06:04:56 EST 2008
In that case, please file a bug:
http://trac.osgeo.org/mapguide/newticket
Please include any files, config, etc. that will help me fix the bug.
You can go to this page:
http://localhost/mapguide/mapagent/describeschemaform.html
Enter the correct ResourceID for the FeatureSource, and click "Submit".
If you attach the resulting Xml to the ticket, it will probably help me
fix the problem.
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
> I tried the r3481 version too, but the problem still remains...
> ----- Original Message -----
> *From:* Carmelo Saffioti <mailto:csaffi at libero.it>
> *To:* MapGuide Users Mail List
> <mailto:mapguide-users at lists.osgeo.org>
> *Sent:* Friday, November 28, 2008 11:23 AM
> *Subject:* Re: [mapguide-users] Possible bug with FDO Provider for
> MySql
> I'm using the 1.0.9 version. I wasn't able to find the newer
> version. Where can I find it?
> Cheers
> Carmelo
> *From:* Kenneth Skovhede, GEOGRAF A/S <mailto:ks at geograf.dk>
> *Sent:* Friday, November 28, 2008 10:49 AM
> for MySql
> It looks like a bug in Maestro.
> Feel free to create a ticket for the problem.
> If you can create something that allows me to reproduce the
> problem locally, I will try to fix it.
> Are you using 1.0.9 or the newer r3481?
> There was a bugfix for database featuresources that is not in
> 1.0.9.
>> Hi everybody!
>> I'm using MapGuide Maestro for creating a data connection to
>> a MySql db. When I add a new Dataconnection with "OSGeo FDO
>> Provider for MySql" everything is ok, in fact if I click on
>> "Test connection" I get: Provider reported no errors... I
>> assigned database, server, port, username and password, but
>> there's nothing about tables...
>> The problem is when, after creating a new layer, I try to
>> choose as feature resource the MySql Dataconnection before
>> created. I get the following error message:
>> "failed to read schema from data source"
>> If I use MapGuide Studio for doing the same things,
>> everything works fine! So, is there anything wrong in what
>> I'm doing or is there any bug in Maestro??
>> Thank you very much in advance
>> Carmelo
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081128/e8b5798e/attachment.html
