[mapguide-users] Maestro issues
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Oct 3 05:20:30 EDT 2008
1. Do you mean something like:
The preview does not display the composite lines together, but only the
selected line?
If so, please file the ticket.
2. Defininetly post the ticket.
Anything that gives an error while saving should be fixed.
3. I'm not quite sure what you mean.
If you mean that you refresh the browser window and get an error, that
is not somehing I can fix.
The preview works by saving you current map as a temporary resource.
If you refresh it, you are re-reading the map as it was when you first
preview it.
Since the layers referenced are no longer in the expected places, it
does not work.
If you mean that you press the "Preview" button after moving the suff
around, it should work.
If it does not, I expect that the Map is actually refreshed, but the
display holds a stale copy of map.
When you press preview, you preview the stale copy.
If you close the map, open it again, and then press preview, it should work.
If the problem is the latter, please post a ticket, and I'll try to
handle it.
Thank you for taking the time to report the issues.
Regards, Kenneth Skovhede, GEOGRAF A/S
andresch at iway.na skrev:
> I have 3 issues on Maestro 1.09 and before adding them to the trac,
> please review first:
> 1) When adding composite lines like to highways,meaning I have added 2
> line type entries in the composite line section. the lines in only
> displayed when I select the line.
> 2) Also on the composite lines; if I have added 2 line types, but not
> deleting the 2nd line type enrty (to go back to single linetype), I
> de-select the composite line checkbox. When trying to save, I got an error.
> 3) After I completed defining data connections, layers, maps and layouts
> and successfully view the map; and I then move these into sub-folders
> for each (like Data, Layers, Maps, Layouts folders). When refreshing the
> map previewed, I got an error. I had to delete the layers from the
> layout and add them again. Then refresh the map works 100%
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
