[ZS1] Re: [mapguide-users] StatusScale issue in scale ranges
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sun Oct 5 12:11:02 EDT 2008
That sounds VERY strange.
So you have:
15001 -> Visible
15000 -> Invisible
14999 -> Visible
But ONLY when typing the range in the scale box?
Regards, Kenneth Skovhede, GEOGRAF A/S
Rodolfo Moreno skrev:
> Hi Kenneth,
> I know the behavior of the scale ranges.
> My case is the following¨
> I have two scale ranges
> 0-15000
> 15001 - infinite
> when I start the map can see the layer according to 15001 - inifinte scale
> range, however when you do zoom in until 15000 using the status scale the
> layer disappears. When I do the same usign the slider, zoom rectangle or
> zoom in tool the layer shows up according to 0-15000 scale ranges.
> It happen with any of viewers (fusion, ajax or dwf).
> Regards,
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Can you clarify the problem a bit?
>> If you have a layer with scale ranges:
>> 0-2000 : Red dots
>> 2001-Infinite : Blue dots
>> Does it change from blue to red if you type in "2000" in the status bar
>> at the bottom?
>> Does it change if you use the slider (to the same range)?
>> Does it change if you drag a rectange (to the same range)?
>> (The change is expected behavior)
>> If you have ranges:
>> 0-2000
>> 4000-Infinite
>> The layer will be invisible in the range [2001-3999], which is correct
>> behavior.
>>> Hi all,
>>> I got an issue in mapguide 2.0.1.
>>> Layers with different scale ranges become invisible when you do zoom in
>>> with
>>> the StatusScale until to achieve one of the scale ranges.
>>> It happens with any of the viewers (AJAX, DWF or FUSION), which is why I
>>> think that the problem is the mapguide server.
>>> I don't know whether this issue has been solved in the 2.0.2 version
>>> I would like to know whether someone has gotten the same problem.
>>> Regards
>>> Rodolfo Moreno
>>> CivilEng
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Rodolfo Moreno
> CivilEng
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081005/22ec50da/attachment.html
