[mapguide-users] [ZS1] Re: StatusScale issue in scale ranges
Rodolfo Moreno
rmoreno at voxiva.com
Mon Oct 6 12:23:32 EDT 2008
Hi Kenneth,
that's rigth, although I've just realized of it today.
Regards,
Kenneth Skovhede, GEOGRAF A/S wrote:
> That sounds VERY strange.
> So you have:
> 15001 -> Visible
> 15000 -> Invisible
> 14999 -> Visible
> But ONLY when typing the range in the scale box?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Rodolfo Moreno skrev:
>> Hi Kenneth,
>> I know the behavior of the scale ranges.
>> My case is the following¨
>> I have two scale ranges
>> 0-15000
>> 15001 - infinite
>> when I start the map can see the layer according to 15001 - inifinte
>> scale
>> range, however when you do zoom in until 15000 using the status scale the
>> layer disappears. When I do the same usign the slider, zoom rectangle or
>> zoom in tool the layer shows up according to 0-15000 scale ranges.
>> It happen with any of viewers (fusion, ajax or dwf).
>> Regards,
>>> Can you clarify the problem a bit?
>>> If you have a layer with scale ranges:
>>> 0-2000 : Red dots
>>> 2001-Infinite : Blue dots
>>> Does it change from blue to red if you type in "2000" in the status bar
>>> at the bottom?
>>> Does it change if you use the slider (to the same range)?
>>> Does it change if you drag a rectange (to the same range)?
>>> (The change is expected behavior)
>>> If you have ranges:
>>> 0-2000
>>> 4000-Infinite
>>> The layer will be invisible in the range [2001-3999], which is correct
>>> behavior.
>>>> Hi all,
>>>> I got an issue in mapguide 2.0.1.
>>>> Layers with different scale ranges become invisible when you do zoom in
>>>> with
>>>> the StatusScale until to achieve one of the scale ranges.
>>>> It happens with any of the viewers (AJAX, DWF or FUSION), which is why
>>>> I
>>>> think that the problem is the mapguide server.
>>>> I don't know whether this issue has been solved in the 2.0.2 version
>>>> I would like to know whether someone has gotten the same problem.
>>>> Regards
>>>> Rodolfo Moreno
>>>> CivilEng
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Rodolfo Moreno
>> CivilEng
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/StatusScale-issue-in-scale-ranges-tp1142302p1301280.html
