[mapguide-users] what's holding people back from upgrading to 2.0?
Jonathan Manafi
jonathan.manafi at cctechnol.com
Tue Oct 7 15:57:20 EDT 2008
Short answer: yes.
However, testing the package that is available in that ticket, I am only
getting CPU load issues using the AGG renderer. The GD renderer seems to
work fine with that small subset of our data. But, when I test our
entire site maps with either renderer, I am still having the same
issues. AGG causes CPU lockup as well as memory-hogging, and GD still
causes memory-hogging.
It is still being caused by the same layer, so I will see if it's
possible to get an updated dataset to test with.
Jason Birch wrote:
> This issue is identified in RFC 52 as AGG-specific, and was in my
> initial testing as well:
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc52
> Are you seeing the same results when you switch to the GD renderer in
> 2.0.x?
> Jason
> -----Original Message-----
> From: Jonathan Manafi
> Subject: Re: [mapguide-users] what's holding people back from upgrading
> to 2.0?
> We experienced extreme CPU and/or memory consumption when we tested MGOS
> 2.x with some of our data. We created a ticket(#459
> https://trac.osgeo.org/mapguide/ticket/459) to document our problems,
> and I have been testing this issue with all of the updated releases, and
> I continue to see the same results. We can't zoom all the way into our
> maps without the server locking up and consuming all of the CPU, which
> is stopping us from moving a production environment to MGOS 2. We've
> been able to modify 1.2 to suit our needs for almost everything with
> plugins; and if we couldn't add a specific feature, we went in another
> direction.
> So far, that has been a killer for our migration.
