[mapguide-users] installing mapguide on server with php already
on it
kawalski
jhagedorn at bannerassociates.com
Thu Oct 9 09:17:17 EDT 2008
i have php 5.2.4 installed on the server. i am on Windows. both phps are in
the PATH variable.
Dave Wilson-3 wrote:
> What version of PHP is already installed. MapGuide only works with the
> installed version. PHP also doesn't play well side by side or support dual
> instances of near versions out of the box. This is documented on the PHP
> site. http://us.php.net/configuration
> Are you installing on Windows or Linux.
> Previous discussions in the list recommend adding the MapGuide PHP install
> directory to your system path (Windows).
> You can also check your registry to see if the HKLM...entry points to the
> installed directory (Windows).
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of kawalski
> Sent: Wednesday, October 08, 2008 3:19 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] installing mapguide on server with php already
> on it
> i am trying to install mapguide on a server that is running IIS and
> already
> has php installed. i can not get the mapguide php pages to work. i can't
> get to the login page for adimistrator. i have changed settings in IIS a
> number of times to get .php to point to either of the php directories.
> when
> i removed the original php i could not get the other php pages to work by
> pointing them to the mapguide version. how do you get the 2 php's to play
> together?
> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19880766.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19898310.html
