[mapguide-users] SQL Import Spatial Data
Jason Birch Jason.Birch at nanaimo.ca
Fri Oct 10 15:19:55 EDT 2008
I wasn't saying that you have to map your application users to MapGuide
users 1:1.  You can create a single user for each role (reader, writer)
and have the app use these to connect to MapGuide, switching based on
the end user's AD group membership.
You could probably get away with using the Author ( for write-based
applications) and Anonymous (for read-only) users, but I'd probably
create one set of users per application.
Jason
Subject: Re: [mapguide-users] SQL Import Spatial Data
IOW, you can't simply do away with mg users and groups.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081010/74cdfc62/attachment.html
