[mapguide-users] installing mapguide on server with php already
on it
kawalski
jhagedorn at bannerassociates.com
Fri Oct 10 15:47:26 EDT 2008
i put the dll's in the ext directory and put the reference in the php.ini. i
have used the installers to put mapguide on. the instructions are for
building everything from scratch and is done with the installers. i think i
have everything done with the config of IIS. the viteral directories are
created with the installers and have checked that the .php looks at the php
on c:\program files\php. this shouldn't be this difficult.
thanks
kawalski
Ed Jobe wrote:
> You need to install the dll mentioned and configure php.ini according to
> those directions. Also, if it can't find php_mapguide.dll, you need to
> follow the instructions from the download site for configuring iis.
> Ed Jobe
> ----- Original Message ----
> From: kawalski <jhagedorn at bannerassociates.com>
> To: mapguide-users at lists.osgeo.org
> Sent: Friday, October 10, 2008 11:40:37 AM
> Subject: RE: [mapguide-users] installing mapguide on server with php
> already on it
> that post really didn't do anything for me. everything is on one
> machine. i
> have got the mapguide looking at the php that was on the machine before.
> i
> have phpinfo() on the login page and it shows that it is looking at the
> right php. i have removed the php in path that had it going to the
> mapguide
> directory. i have make sure that the mapguide server is running. when i
> restart IIS and go tothe login.php, the first thing i get is an error box
> that says it can't find the php_MapGuideApi.dll. it is in the ext
> directory
> under the php directory. the extention_dir points to the ext directory
> under the C:\program files\php\ext. so what is the next step? i even
> tried
> yesterday out of frustration to remove everything and installed mapguide
> with the apache and i couldn't even get the login.php to come up. i'm
> further ahead so far with the IIS install but i have been dinking with
> this
> now for the better part of 5 days. the demo i seen at the MN GIS/LIS
> conference last week made this look so easy.
> thanks
> kawalski
> Ed Jobe wrote:
>> See this post.
>> http://www.nabble.com/forum/ViewPost.jtp?post=19729894&framed=y
>> kawalski wrote:
>>> ok, i have at least been able to get to the login screen but get a 500
>>> error when i try to log in. i have put the phpinfo() in the login php
>>> page and everything is pointing to the correct directories.
>>> thanks
>>> Dave Wilson-3 wrote:
>>>> Do a diff between the MapGuide php.ini and your existing on to see the
>>>> changes that are required. There are only a couple of changes. You will
>>>> also have to copy the additional php extension files included for
>>>> mapguide to your directory. Again a diff between the directories might
>>>> be the easiest way to go. I just don't know all the files off the top
>>>> of
>>>> my head.
>>>> You then have to change the isapi mapping on the mapguide virtual
>>>> directory in IIS to point to your instance.
>>>> I think that's it.
>>>> Dave
>>>> -----Original Message-----
>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of kawalski
>>>> Sent: Thursday, October 09, 2008 8:39 AM
>>>> already on it
>>>> so, if i remove the php directory under the mapguide directories and
>>>> remove
>>>> the instance in PATH, then mapguide would look at the other php i
>>>> already
>>>> have installed? is there anything else that would need to be done to
>>>> make
>>>> mapguide look to the other php?
>>>> thanks
>>>>> Because you are using the same version, whichever is first in the path
>>>>> is
>>>>> likely to get used to set the php.ini when IIS loads. I don't believe
>>>>> you
>>>>> will get both of them to work. The registry entry also only points to
>>>>> one
>>>>> of the instances so again it's not really designed to allow both. A
>>>>> phpinfo page might help indicate which instance is getting loaded.
>>>>> You will likely have to decide which instance of PHP you wish to use
>>>>> and
>>>>> configure it for all the applications you need unless someone else has
>>>>> discovered a way to do this without recompiling php for their needs.
>>>>> Regards,
>>>>> Dave
>>>>> Sent: Thursday, October 09, 2008 7:17 AM
>>>>> already on it
>>>>> i have php 5.2.4 installed on the server. i am on Windows. both phps
>>>>> are
>>>>> in
>>>>> the PATH variable.
>>>>>> What version of PHP is already installed. MapGuide only works with
>>>>>> the
>>>>>> installed version. PHP also doesn't play well side by side or support
>>>>>> dual
>>>>>> instances of near versions out of the box. This is documented on the
>>>>>> PHP
>>>>>> site. http://us.php.net/configuration
>>>>>> Are you installing on Windows or Linux.
>>>>>> Previous discussions in the list recommend adding the MapGuide PHP
>>>>>> install
>>>>>> directory to your system path (Windows).
>>>>>> You can also check your registry to see if the HKLM...entry points to
>>>>>> the
>>>>>> installed directory (Windows).
>>>>>> Dave
>>>>>> Sent: Wednesday, October 08, 2008 3:19 PM
>>>>>> Subject: [mapguide-users] installing mapguide on server with php
>>>>>> already
>>>>>> on it
>>>>>> i am trying to install mapguide on a server that is running IIS and
>>>>>> already
>>>>>> has php installed. i can not get the mapguide php pages to work. i
>>>>>> can't
>>>>>> get to the login page for adimistrator. i have changed settings in
>>>>>> IIS a
>>>>>> number of times to get .php to point to either of the php
>>>>>> directories.
>>>>>> when
>>>>>> i removed the original php i could not get the other php pages to
>>>>>> work
>>>>>> by
>>>>>> pointing them to the mapguide version. how do you get the 2 php's to
>>>>>> play
>>>>>> together?
>>>>>> View this message in context:
>>>>>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19880766.html
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19898310.html
>>>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19900334.html
> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19923801.html
View this message in context: http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19924930.html
