[mapguide-users] Maestro: can't find the table containing the geometry field with SQLServerSpatial
Carl carlshe at 163.com
Wed Oct 15 08:04:01 EDT 2008
Yes, I tried http://localhost/mapguide/mapagent/index.html. the returned xml
covers only fewer tables of database.
Then I create a new database, add table one by one, and try 'describeschema'
from above web page.  I couldn't find the rule the FDO/MapGuide used to enum
the tables. all the tables are owned by the same dbo, but when the count of
tables arrives at a large number, the return would become incomplete. which
is chosen to be returned can't be determined by a fixed rule, or at least I
can't find the rule.
Where I should report this problem?
Could you please help me?
Thank you!
Kenneth Skovhede, GEOGRAF A/S wrote:
> I guess there should be an "unmapped type" - type, to deal with
> situations like this.
> You can set it to "string", and it should read out just fine.
> I have created a ticket for the problem:
> http://trac.osgeo.org/mapguide/ticket/724
> As you may have noticed, Maestro issues calls to a web interface on the
> MapGuide server:
> On this test form/web interface, you can try the "Feature" ->
> "DescribeSchema".
> Leave the "Schema" field blank, and you will get the output from
> MapGuide, which in turn should be
> the output directly from FDO.
> If the tables are missing there, you cannot get them into Maestro.
> If the tables are present, please file a bug report for Maestro, and
> include the resulting xml in the ticket.
> If the tables are missing (which I suspect), it could be a problem with
> permissions.
> Could it be that the provider only shows tables which are owned by the
> login user?
> Regards, Kenneth Skovhede, GEOGRAF A/S
View this message in context: http://www.nabble.com/Maestro%3A-can%27t-find-the-table-containing-the-geometry-field-with-SQLServerSpatial-tp19977173p19992122.html
