[mapguide-users] fdo autocad map from mapguide
Nandorov nandorov at gmail.com
Fri Oct 17 13:59:24 EDT 2008
hi,
i proved postgis fdo provider 3.3 from
http://www.geomapgis.com/web/geomap-group/fdo/index.html
and works well with mapguide 2009.
i wonder if that provider works for autocadmap 3d 2009, i did the
configuration like with mapguide. the provider makes the connection to the
database, but it fails when reading the schema.
"there was a problem accesing the connection schema information"
i added the bin folder of postgre at enviroment variable path. just in case,
it's necesary to install postgresql on the local machine, or just with the
bin folder it should work? (if it works, ofc)
thanks
View this message in context: http://www.nabble.com/fdo-autocad-map-from-mapguide-tp20038089p20038089.html
