[mapguide-users] fdo autocad map from mapguide
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sat Oct 18 14:43:26 EDT 2008
If you get no replies, try asking on an Autocad forum, or perhaps on the
FDO mailing list.
Regards, Kenneth Skovhede, GEOGRAF A/S
Nandorov skrev:
> hi,
> i proved postgis fdo provider 3.3 from
> http://www.geomapgis.com/web/geomap-group/fdo/index.html
> and works well with mapguide 2009.
> i wonder if that provider works for autocadmap 3d 2009, i did the
> configuration like with mapguide. the provider makes the connection to the
> database, but it fails when reading the schema.
> "there was a problem accesing the connection schema information"
> i added the bin folder of postgre at enviroment variable path. just in case,
> it's necesary to install postgresql on the local machine, or just with the
> bin folder it should work? (if it works, ofc)
> thanks
