[mapguide-users] Nothing is working or what I'm doing wrong?
Antonis Mihalas amihalas at yahoo.gr
Mon Oct 20 10:33:35 EDT 2008
As far as I know, this is not possible, because
MgMap map = new MgMap(resourceSrvc); it takes as argument a siteConnection...
When you say refresh the client you mean just to write one line *.js?
without importing anything?
I'm asking, cause parent.parent.Refresh();
              or
parent.mapFrame.Refresh();
doesn't do anything...
--- Στις Δευτ., 20/10/08, ο/η Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk> έγραψε:
Από: Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
Θέμα: Re: [mapguide-users] Nothing is working or what I'm doing wrong?
Προς: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Ημερομηνία: Δευτέρα, 20 Οκτώβριος 2008, 16:53
The viewer overwrites the runtime map on startup, so if you run this
before starting the viewer, your changes will be lost.
You should not create a new runtime map, but open the one the viewer
creates for you, modify it, save it, and refresh the client.
I belive the correct sequence would be:
map.Open(mapName):
The viewer takes a string like:
"Library://Folder/MapName.MapDefinition"
and uses the map name:
"Folder/MapName"
You must use the same name in your code, or you won't get to the runtime
map.
If you want the layer to show when the map loads, have a look at this:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/AddInitialLayer
You can perform the same actions without the MaestroAPI if you like, but
you have to deal with the xml in raw form.
Regards, Kenneth Skovhede, GEOGRAF A/S
Galois skrev:
> Whatever I try to do it's just not working.
> Add a new layer?
> The layer is added but never shown
> Add a point? Nothing
> Add a new group?
> The Group is added but never shown
> So, I simple tried to change the LegendLabel of an existing layer.
> Nothing happened again...
> If anyone can tell me what I am doing wrong I would appreciate it.
> Code follows:
> using System;
> using System.Data;
> using System.Configuration;
> using System.Web;
> using System.Web.Security;
> using System.Web.UI;
> using System.Web.UI.WebControls;
> using System.Web.UI.WebControls.WebParts;
> using System.Web.UI.HtmlControls;
> using OSGeo.MapGuide;
> using System.Xml;
> using System.IO;
> using System.Text;
> public partial class _Default : System.Web.UI.Page
>     public string sessionId;
>     public string webLayout;
>     public MgLayer tmpLayer;
>     protected System.Web.UI.HtmlControls.HtmlGenericControl Frame1;
>     protected void Page_Load(object sender, EventArgs e)
>         string physicalPath = @"C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\webconfig.ini";
>         try
>             MapGuideApi.MgInitializeWebTier(physicalPath);
>             passAndSession();
>             //Associate a session ID with the MgSiteConnection Object
>             MgUserInformation userInfo_new = new
> MgUserInformation(sessionId);
>             MgSiteConnection siteConnection = new MgSiteConnection();
>             siteConnection.Open(userInfo_new);
>             // Get an instance of the required service(s)
>             MgResourceService resourceSrvc =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
>             MgFeatureService featureSrvc =
(MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
>             MgMap map = new MgMap(siteConnection);
>             webLayout =
"Library://GoSpatial/Web+Layouts/Autostrada+Brescia+Padova+Map.WebLayout";
>             MgResourceIdentifier resId = new
> MgResourceIdentifier("Library://GoSpatial/Maps/Italy
Map.MapDefinition");
>             String mapName = resId.GetName();
>             MgResourceIdentifier mapStateId = new
> MgResourceIdentifier("Session:" + sessionId + "//" +
mapName + "." +
> MgResourceType.Map);
>             createSaveOpen(map, resourceSrvc, resId, mapName, mapStateId);
>             MgLayerBase firstLayer = map.GetLayers().GetItem(0);
>             firstLayer.SetLegendLabel("CHANGE");
>             map.Save(resourceSrvc, mapStateId);
>         catch (Exception ex)
>             throw (ex);
> Thx in advanced!
> PS I have never but never in my life try to do something and in 2 weeks
not
> shown even a small improvement...
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
__________________________________________________
Χρησιμοποιείτε Yahoo!;
Βαρεθήκατε τα ενοχλητικά μηνύματα (spam);   Το Yahoo! Mail διαθέτει την καλύτερη δυνατή προστασία κατά των ενοχλητικών μηνυμάτων
http://mail.yahoo.gr
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081020/391a8130/attachment.html
