[mapguide-users] Nothing is working or what I'm doing wrong?
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Oct 20 15:35:19 EDT 2008
You are correct about the new MgMap(...) call. My mistake.
So it becomes:
MgMap map = new MgMap(siteConnection);
map.Open(mapname);
map.GetLayers().GetItem(0).SetLegend("Changed");
map.Save(resourceSrvc, mapname);
Yes, I meant the Refresh() call.
If nothing happens, either you are not calling the correct frame, or the
map has not been saved.
Try to use FireFox and the FireBug plugin to see where the calls go.
Regard, Kenneth Skovhede, GEOGRAF A/S
Antonis Mihalas skrev:
> As far as I know, this is not possible, because
> MgMap map = new MgMap(resourceSrvc); it takes as argument a siteConnection...
> When you say refresh the client you mean just to write one line *.js?
> without importing anything?
> I'm asking, cause parent.parent.Refresh();
>               or
> parent.mapFrame.Refresh();
> doesn't do anything...
> --- Στις *Δευτ., 20/10/08, ο/η Kenneth Skovhede, GEOGRAF A/S
> /<ks at geograf.dk>/* έγραψε:
>     Από: Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
>     Θέμα: Re: [mapguide-users] Nothing is working or what I'm doing wrong?
>     Προς: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
>     Ημερομηνία: Δευτέρα, 20 Οκτώβριος 2008, 16:53
>     The viewer overwrites the runtime map on startup, so if you run this
>     before starting the viewer, your changes will be lost.
>     You should not create a new runtime map, but open the one the viewer
>     creates for you, modify it, save it, and refresh the client.
>     I belive the correct sequence would be:
>     map.Open(mapName):
>     The viewer takes a string like:
>     "Library://Folder/MapName.MapDefinition"
>     and uses the map name:
>     "Folder/MapName"
>     You must use the same name in your code, or you won't get to the runtime
>     map.
>     If you want the layer to show when the map loads, have a look at this:
>     http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/AddInitialLayer
>     You can perform the same actions without the MaestroAPI if you like, but
>     you have to deal with the xml in raw form.
>     Regards, Kenneth Skovhede, GEOGRAF
>      A/S
>     Galois skrev:
>     > Whatever I try to do it's just not working.
>     > Add a new layer?
>     > The layer is added but never shown
>     > Add a point? Nothing
>     > Add a new group?
>     > The Group is added but never shown
>     > So, I simple tried to change the LegendLabel of an existing layer.
>     > Nothing happened again...
>     > If anyone can tell me what I am doing wrong I would appreciate it.
>     > Code follows:
>     > using System;
>     > using System.Data;
>     > using System.Configuration;
>     > using System.Web;
>     > using System.Web.Security;
>     > using System.Web.UI;
>     > using System.Web.UI.WebControls;
>     > using System.Web.UI.WebControls.WebParts;
>     > using System.Web.UI.HtmlControls;
>     > using OSGeo.MapGuide;
>     > using System.Xml;
>     > using System.IO;
>     > using System.Text;
>     > public partial
>      class _Default : System.Web.UI.Page
>     >     public string sessionId;
>     >     public string webLayout;
>     >     public MgLayer tmpLayer;
>     >     protected System.Web.UI.HtmlControls.HtmlGenericControl Frame1;
>     >     protected void Page_Load(object sender, EventArgs e)
>     >         string physicalPath = @"C:\Program
>     Files\MapGuideOpenSource\WebServerExtensions\www\webconfig.ini";
>     >         try
>     >             MapGuideApi.MgInitializeWebTier(physicalPath);
>     >             passAndSession();
>     >             //Associate a session ID with the MgSiteConnection Object
>     >             MgUserInformation userInfo_new = new
>     > MgUserInformation(sessionId);
>     >             MgSiteConnection siteConnection = new MgSiteConnection();
>      siteConnection.Open(userInfo_new);
>     >             // Get an instance of the required service(s)
>     >             MgResourceService resourceSrvc =
>     (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
>     >             MgFeatureService featureSrvc =
>     (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
>     >             webLayout =
>     "Library://GoSpatial/Web+Layouts/Autostrada+Brescia+Padova+Map.WebLayout";
>     >             MgResourceIdentifier resId = new
>     > MgResourceIdentifier("Library://GoSpatial/Maps/Italy
>     Map.MapDefinition");
>     >             String mapName = resId.GetName();
>     >             MgResourceIdentifier mapStateId = new
>     > MgResourceIdentifier("Session:" + sessionId + "//"
>     mapName + "." +
>     > MgResourceType.Map);
>     >             createSaveOpen(map, resourceSrvc, resId, mapName, mapStateId);
>     >             MgLayerBase firstLayer = map.GetLayers().GetItem(0);
>     >             firstLayer.SetLegendLabel("CHANGE");
>     >             map.Save(resourceSrvc, mapStateId);
>     >         catch (Exception ex)
>     >             throw (ex);
>     > Thx in advanced!
>     > PS I have never but never in my life try to do something and in 2 weeks
>     not
>     > shown even a small improvement...
>     _______________________________________________
>     mapguide-users mailing
>      list
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
> __________________________________________________
> Χρησιμοποιείτε Yahoo!;
> Βαρεθήκατε τα ενοχλητικά μηνύματα (spam); Το Yahoo! Mail διαθέτει την
> καλύτερη δυνατή προστασία κατά των ενοχλητικών μηνυμάτων
> http://mail.yahoo.gr
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081020/6825eaa9/attachment.html
