[mapguide-users] RE: MapGuide Open Source Web Studio
Jason Birch Jason.Birch at nanaimo.ca
Mon Oct 20 12:26:23 EDT 2008
You can also add data by manipulating the APIs through the web forms
under /mapguide/mapagent/index.html.  This can be a bit painful though,
especially if you are trying to add managed data.
I'm surprised that Maestro is crashing for you so often though; it's
working fine in my test cases...
What operations are you performing when you see crashes?  If the problem
can be reproduced, Kenneth will have a chance of fixing it.
Jason
-----Original Message-----
Subject: RE: [mapguide-users] RE: MapGuide Open Source Web Studio
That's unfortunate because Maestro crashes on me rather often... Is
there no other alternative to adding data? This might be a deal breaker
if I must shell out money for Autodesk's Web Studio just to get a
working way of adding data...
