[mapguide-users] After adding shape files with Maestro, layers, map, etc.
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Oct 20 15:45:09 EDT 2008
I think you have to restart the MapGuide service after adding an alias,
but I'm not sure.
For starters, you can also enter the absolute path manually (keep in
mind that it is the path as it looks on the server).
I have used SHP data without setting the temp folder.
I have not used FlexibleLayouts, so I can only guess that the Fusion
templates do not correlate with your map list in some way.
You can try to create a WebLayout and add the map to that one, that will
at least tell you if the error is in Fusion.
Regards, Kenneth Skovhede, GEOGRAF A/S
Nelson Soto skrev:
> I basically copied most of the Sheboygan stuff, including the
> FlexibleLayouts, but supplemented the things I saw Sheboygan reference
> with my sample data. When trying to preview the map via the
> FlexibleLayouts, I get the layout but no data. A JS error occurs saying
> Error Line 120: 'maps' is null or not an object.
> So, I'm assuming I haven't set something up correctly.
> For my SHP connections, must I set up a temp dir? I have tried to set
> up an Alias  to a tempdir but Maestro keeps telling me there are no
> aliases set despite that I went through Web Site Admin and set one up.
> The settings through Web Admin were saved successfully.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081020/cd8bce9c/attachment.html
