[mapguide-users] Shapefile Features Not Rendering
GISDOTNET aaron.ford at ntierdigm.com
Wed Oct 22 12:16:05 EDT 2008
Jason,
I hate to say this but it made the issue even worse (see inserted images).
Any other ideas?
Thanks,
Aaron
GISDOTNET wrote:
> Jason,
> For my own education and perhaps others reading this thread, what does AGG
> and GD stand for and what is the difference between the two renderers?
> Regarding the second issue, the FDO provider doesn't recognize annotation
> as annotation and sees it as a line type. Maybe that's by design and I'm
> not using it correctly. Let me know. Regardless, from what I have read and
> seen first hand is that the FDO provider for SDE is very slow and seldom
> used.
> Thanks,
> Aaron
> JasonBirch wrote:
>> Hi Aaron,
>> Your first issue may be due to a defect in the AGG renderer that does
>> not display some features at small scales.
>> http://trac.osgeo.org/mapguide/ticket/632
>> Try switching the renderer to GD in your serverconfig.ini file and
>> restarting the MapGuide service to see if that's the case.
>> Can't offer any guidance on the second issue... what kind of difficulty
>> are you having?  Is MapGuide's collision detection hiding some of the
>> annotation?
>> Jason
>> -----Original Message-----
>> From: GISDOTNET
>> Subject: [mapguide-users] Shapefile Features Not Rendering
>> 1.) Some of the shapefiles do not fully render all of their features
>> depending on scale e.g. at start up not all the parcel polygons are
>> drawn.
>> [snip]
>> 2.) How are people handling annotation from ESRI data sources? All our
>> data
>> is in SDE; however, we had significant display/rendering issues which
>> lead
>> to dropping everything to shapefiles. As a result, we are experiencing
>> difficulty having all the annotation converted to labeled lines render
>> in
>> our MGOS application.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://www.nabble.com/file/p20114392/Image1.jpeg
http://www.nabble.com/file/p20114392/Image2.jpeg
View this message in context: http://www.nabble.com/Shapefile-Features-Not-Rendering-tp20103332p20114392.html
