[mapguide-users] Shapefile Features Not Rendering
Jason Birch
Jason.Birch at nanaimo.ca
Wed Oct 22 13:10:52 EDT 2008
Odd... So, from what I can tell, the utility connections are
disappearing?
This is definitely worth a trac ticket. Are you able to provide a clip
of your shapefiles, showing just the area (or slightly larger) in your
screen shots? If so, then please create a Trac ticket, attaching the
clipped shapefiles (zipped), the images, and a screen shot from ArcGIS
showing what it is supposed to look like. Information on filing tickets
can be found here:
http://trac.osgeo.org/mapguide/wiki/SubmitTicket
I don't think there is any documentation on converting from SDE or SHP
to SDF, but you can do this with either
FDO2FDO:
http://www.sl-king.com/Fdo2Fdo/download/download.html
FDO Toolbox:
http://code.google.com/p/fdotoolbox/
Also, it looks like Traian has modified the SQLite conversion tool so
that it can output SDF, but it's only available as source code
currently.
http://trac.osgeo.org/fdo/changeset/4143
Jason
-----Original Message-----
Subject: RE: [mapguide-users] Shapefile Features Not Rendering
I hate to say this but it made the issue even worse (see inserted
images).
Any other ideas?
