[mapguide-users] Cyrillic alphabet/Encoding problem
Stefan Dalakov
s.dalakov at mapware.net
Fri Oct 24 02:29:54 EDT 2008
I would suggest that the data in the SHP file is encoded using the
so-called DOS-cyrillic code page. I do not remember now the exact
code-page name, but I can come back to this later. At least this works
in my case.
Have a look at http://www.bgmapguide.com/mapguide/rila/rila.php , it is
using mgos 1.2 but I don't think this makes any difference.
Stefan Dalakov
milko_velichkov wrote:
> Unfortunately that's doesn't work in my case :(
> http://www.nabble.com/file/p20144623/t.jpeg
> Traian Stanev wrote:
>> Yes, SHP files and encodings is trouble... You can try to force the
>> encoding to UTF-8 by adding a .CPG file alongside your SHP file (with the
>> same filename as the .SHP). The contents should be a single line of text,
>> saying "UTF-8", without the quotes. This will hint the FDO provider for
>> SHP files to use that encoding. No guarantee that would fix it though...
>> Another thing you can do to identify the cause of the problem is try to
>> use a constant Cyrillic string as a label for your geometry. If that shows
>> up fine in MapGuide, then the problem is upstream (in the FDO provider),
>> otherwise it's a problem in the MapGuide code.
>> Traian
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>>> bounces at lists.osgeo.org] On Behalf Of milko_velichkov
>>> Sent: Thursday, October 23, 2008 1:32 AM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: RE: [mapguide-users] Cyrillic alphabet/Encoding problem
>>> Under "Selection" tab, when I have attribute information in Cyrillic
>>> from a
>>> SHP data source, they appear like маймуница :). Same with all labels
>>> within
>>> the Map window. Encoding used by default is UTF-8 (I don't have an idea
>>> how
>>> to change it within the MapGuide environment).
>>> Milko
>>>> What exactly is the problem you are seeing? Also, are you using
>>> Unicode or
>>>> some other encoding for the Cyrillic in your data source?
>>>> Traian
>>>>> Sent: Wednesday, October 22, 2008 4:26 AM
>>>>> Subject: [mapguide-users] Cyrillic alphabet/Encoding problem
>>>>> Hi,
>>>>> Did anyone else has a problem with the visualization/encoding of
>>>>> Cyrillic
>>>>> letters when selecting features from within MapGuide?
>>>>> View this message in context: http://www.nabble.com/Cyrillic-
>>> alphabet-
>>>>> Encoding-problem-tp20104783p20104783.html
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> View this message in context: http://www.nabble.com/Cyrillic-alphabet-
>>> Encoding-problem-tp20104783p20124621.html
