[mapguide-users] Cyrillic alphabet/Encoding problem
Nisha P
nishap97 at gmail.com
Fri Oct 24 07:26:08 EDT 2008
is it use ajaxviewer or dwfviewer?if it is ajaxviewer then how can i get
that type of map in the interface??
On Fri, Oct 24, 2008 at 11:59 AM, Stefan Dalakov <s.dalakov at mapware.net>wrote:
> I would suggest that the data in the SHP file is encoded using the
> so-called DOS-cyrillic code page. I do not remember now the exact code-page
> name, but I can come back to this later. At least this works in my case.
> Have a look at http://www.bgmapguide.com/mapguide/rila/rila.php , it is
> using mgos 1.2 but I don't think this makes any difference.
> Stefan Dalakov
> milko_velichkov wrote:
>> Unfortunately that's doesn't work in my case :(
>> http://www.nabble.com/file/p20144623/t.jpeg
>> Traian Stanev wrote:
>>> Yes, SHP files and encodings is trouble... You can try to force the
>>> encoding to UTF-8 by adding a .CPG file alongside your SHP file (with the
>>> same filename as the .SHP). The contents should be a single line of text,
>>> saying "UTF-8", without the quotes. This will hint the FDO provider for
>>> SHP files to use that encoding. No guarantee that would fix it though...
>>> Another thing you can do to identify the cause of the problem is try to
>>> use a constant Cyrillic string as a label for your geometry. If that
>>> shows
>>> up fine in MapGuide, then the problem is upstream (in the FDO provider),
>>> otherwise it's a problem in the MapGuide code.
>>> Traian
>>>> -----Original Message-----
>>>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>>>> bounces at lists.osgeo.org] On Behalf Of milko_velichkov
>>>> Sent: Thursday, October 23, 2008 1:32 AM
>>>> To: mapguide-users at lists.osgeo.org
>>>> Subject: RE: [mapguide-users] Cyrillic alphabet/Encoding problem
>>>> Under "Selection" tab, when I have attribute information in Cyrillic
>>>> from a
>>>> SHP data source, they appear like маймуница :). Same with all labels
>>>> within
>>>> the Map window. Encoding used by default is UTF-8 (I don't have an idea
>>>> how
>>>> to change it within the MapGuide environment).
>>>> Milko
>>>>> What exactly is the problem you are seeing? Also, are you using
>>>> Unicode or
>>>>> some other encoding for the Cyrillic in your data source?
>>>>> Traian
>>>>>> Sent: Wednesday, October 22, 2008 4:26 AM
>>>>>> Subject: [mapguide-users] Cyrillic alphabet/Encoding problem
>>>>>> Hi,
>>>>>> Did anyone else has a problem with the visualization/encoding of
>>>>>> Cyrillic
>>>>>> letters when selecting features from within MapGuide?
>>>>>> View this message in context: http://www.nabble.com/Cyrillic-
>>>>> alphabet-
>>>>> Encoding-problem-tp20104783p20104783.html
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> View this message in context: http://www.nabble.com/Cyrillic-alphabet-
>>>> Encoding-problem-tp20104783p20124621.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081024/393d9a87/attachment.html
