[mapguide-users] selectAggregate error
Rodolfo Moreno
rmoreno at voxiva.com
Tue Oct 28 12:19:38 EDT 2008
Yeah, that's rigth, I have gotten this error with linked layer (layer with
join to a database)
I have received your new post in my email (with your code), but even it has
not been posted in the forum, odd. I will try it.
Thank very much Moog.
Moog wrote:
> hi, of course. i'm at college now i will send u the code when i arrive
> home.
> btw, my code its just a quicky way to solve this problem. i dont know if
> it's smooth enough. however it helps, i guess. did you get the error in a
> linked layer? i only got that error when i was linking my layer with a
> database.
> regards
> Rodolfo Moreno wrote:
>> Hi Moog I got the same error in .NET.
>> I did what Mauricio suggested (put the selectDistinct statement before
>> that
>> Addfeatureproperty ), but the same error is raised.
>> Could share you share your solution, please.
>> thanks in advance
>> Moog wrote:
>>> that's right. i fixed it making my own algorithm, but it want to know
>>> why
>>> i
>>> got that error. thanks
>>> Mauricio Villablanca wrote:
>>>> Your variable $aggregateOptions is a MgFeatureAggregateOptions object
>>>> and
>>>> your featureService variable is a MgFeatureService object, right?
>>>> Moog wrote:
>>>>> hello,
>>>>> i need some help. Do you know why i get the following error in this
>>>>> line?
>>>>> $dataReader = $featureService->SelectAggregate($resId,
>>>>> $layer->GetFeatureClassName(), $aggregateOptions);
>>>>> where, $aggregateOptions is
>>>>> $aggregateOptions->AddFeatureProperty($this->args['PROPERTYNAME']);
>>>>> $aggregateOptions->SelectDistinct(true);
>>>>> Index is out of range. Exception occurred in method GetItem at line 81
>>>>> in
>>>>> file
>>>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\common\foundation\System/DisposableCollection.cpp
>>>>> - MgFeatureServiceHandler.ProcessOperation line 83 file
>>>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
>>>>> - MgOpSelectFeaturesSpatial.Execute line 110 file
>>>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\feature\OpSelectFeaturesSpatial.cpp
>>>>> - MgServerSelectFeatures.SelectFeatures line 249 file
>>>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\feature\ServerSelectFeatures.cpp
>>>>> - GetItem line 81 file
>>>>> thanks ;)
>>>>> View this message in context:
>>>>> http://www.nabble.com/selectAggregate-error-tp19690193p19690193.html
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> http://n2.nabble.com/selectAggregate-error-tp1121116p1299635.html
>>> http://www.nabble.com/selectAggregate-error-tp19690193p19838822.html
>> Rodolfo Moreno
>> CivilEng
>> http://n2.nabble.com/selectAggregate-error-tp1121116p1384640.html
> http://www.nabble.com/selectAggregate-error-tp19690193p20198179.html
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/selectAggregate-error-tp1121116p1387543.html
