[mapguide-users] selectAggregate error
ralph2008
rmoreno at voxiva.net
Tue Oct 28 19:22:14 EDT 2008
Hi Moog,
I have tried your code and it fixes partially the error.
The code avoids that the error to be raised, however the theming is not done
suitably. I don't know whether it happens to you, but in my case the code is
not theming the first feature of a layer.
I have a featureSource(SHP unmanaged) with 5 features:
featId=1
featId=2
featId=3
featId=4
featId=5
The Id order is created by mapguide studio (I guess).
Then when this layer is themed only the features 2,3,4 and 5 are displayed.
It happens only with linked layers for either individual or numerical
distribution.
I think that is an issue of mapguide, at least 2.0.1 since it's the version
that I have.
Regards
Rodolfo Moreno wrote:
> Yeah, that's rigth, I have gotten this error with linked layer (layer with
> join to a database)
> I have received your new post in my email (with your code), but even it
> has
> not been posted in the forum, odd. I will try it.
> Thank very much Moog.
> Moog wrote:
>> hi, of course. i'm at college now i will send u the code when i arrive
>> home.
>> btw, my code its just a quicky way to solve this problem. i dont know if
>> it's smooth enough. however it helps, i guess. did you get the error in a
>> linked layer? i only got that error when i was linking my layer with a
>> database.
>> regards
>>> Hi Moog I got the same error in .NET.
>>> I did what Mauricio suggested (put the selectDistinct statement before
>>> that
>>> Addfeatureproperty ), but the same error is raised.
>>> Could share you share your solution, please.
>>> thanks in advance
>>> Moog wrote:
>>>> that's right. i fixed it making my own algorithm, but it want to know
>>>> why
>>>> i
>>>> got that error. thanks
>>>> Mauricio Villablanca wrote:
>>>>> Your variable $aggregateOptions is a MgFeatureAggregateOptions object
>>>>> and
>>>>> your featureService variable is a MgFeatureService object, right?
>>>>> Moog wrote:
>>>>>> hello,
>>>>>> i need some help. Do you know why i get the following error in this
>>>>>> line?
>>>>>> $dataReader = $featureService->SelectAggregate($resId,
>>>>>> $layer->GetFeatureClassName(), $aggregateOptions);
>>>>>> where, $aggregateOptions is
>>>>>> $aggregateOptions->AddFeatureProperty($this->args['PROPERTYNAME']);
>>>>>> $aggregateOptions->SelectDistinct(true);
>>>>>> Index is out of range. Exception occurred in method GetItem at line
>>>>>> 81
>>>>>> in
>>>>>> file
>>>>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\common\foundation\System/DisposableCollection.cpp
>>>>>> - MgFeatureServiceHandler.ProcessOperation line 83 file
>>>>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
>>>>>> - MgOpSelectFeaturesSpatial.Execute line 110 file
>>>>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\feature\OpSelectFeaturesSpatial.cpp
>>>>>> - MgServerSelectFeatures.SelectFeatures line 249 file
>>>>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\server\src\services\feature\ServerSelectFeatures.cpp
>>>>>> - GetItem line 81 file
>>>>>> thanks ;)
>>>>>> View this message in context:
>>>>>> http://www.nabble.com/selectAggregate-error-tp19690193p19690193.html
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> http://n2.nabble.com/selectAggregate-error-tp1121116p1299635.html
>>>> http://www.nabble.com/selectAggregate-error-tp19690193p19838822.html
>>> Rodolfo Moreno
>>> CivilEng
>>> http://n2.nabble.com/selectAggregate-error-tp1121116p1384640.html
>> http://www.nabble.com/selectAggregate-error-tp19690193p20198179.html
> Rodolfo Moreno
> CivilEng
> http://n2.nabble.com/selectAggregate-error-tp1121116p1387543.html
View this message in context: http://www.nabble.com/selectAggregate-error-tp19690193p20218082.html
