[mapguide-users] Is it possible to publish a session layer as WMS ?
Mauricio Villablanca mgvillablanca at yahoo.com
Wed Oct 29 15:10:43 EDT 2008
Mauricio Villablanca wrote:
> No. You have to save layers to the Library repository in order to access
> them via WMS. The reason for this is that the mapagent binary expects to
> find the layers there.
> Carl wrote:
>>  I now use MG OS + Openlayers to develop a WebGIS system.
>> I defined a basic map as base layer, and want to use a dynamic layer (
>> for
>> example, clone a existing layer and modify its filter).
>> Normally, it seems I should define a runtimemap wraping the cloned layer.
>> Yes, I tried it. But with openlayers, if the mapguide layer is used as
>> overlayer, there will always be a 'access denied' message shown. I have
>> had
>> a post about the MapGuide overlayer with Openlayers.
>> (http://n2.nabble.com/Access-denied-for-MapGuide-Overlayer-%28with-patched-MapGuide.js%29-tt1307180.html#a1307180)
>> So I intend to use the Mapguide WMS. It seems MapGuide can only publish a
>> predefined layer as WMS.
>> Thanks!
>> Regards, Carl SHE
>> View this message in context:
>> http://n2.nabble.com/Is-it-possible-to-publish-a-session-layer-as-WMS---tp1386781p1386781.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Is-it-possible-to-publish-a-session-layer-as-WMS---tp20206768p20233889.html
