[mapguide-users] Is it possible to publish a session layer as WMS ?
Mauricio Villablanca mgvillablanca at yahoo.com
Wed Oct 29 15:09:06 EDT 2008
No. You have to save layers to the Library repository in order to access them
via WMS. The reason for this is that mapagent.fcgi expects to find the
layers there.
Carl wrote:
>  I now use MG OS + Openlayers to develop a WebGIS system.
> I defined a basic map as base layer, and want to use a dynamic layer ( for
> example, clone a existing layer and modify its filter).
> Normally, it seems I should define a runtimemap wraping the cloned layer.
> Yes, I tried it. But with openlayers, if the mapguide layer is used as
> overlayer, there will always be a 'access denied' message shown. I have
> had
> a post about the MapGuide overlayer with Openlayers.
> (http://n2.nabble.com/Access-denied-for-MapGuide-Overlayer-%28with-patched-MapGuide.js%29-tt1307180.html#a1307180)
> So I intend to use the Mapguide WMS. It seems MapGuide can only publish a
> predefined layer as WMS.
> Thanks!
> Regards, Carl SHE
> http://n2.nabble.com/Is-it-possible-to-publish-a-session-layer-as-WMS---tp1386781p1386781.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Is-it-possible-to-publish-a-session-layer-as-WMS---tp20206768p20233851.html
