[mapguide-users] Adjusting subsequent views
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Sep 5 08:16:15 EDT 2008
That problem sounds different, because you want it done *after* the
runtime map creation.
After you have created the runtime map, you can use the MapGuide API to
manipulate the runtime map,
as well as the layers:
http://mapguide.osgeo.org/files/mapguide/docs/webapi/da/df8/class_mg_map.htm
The GetLayers() call returns a MgLayerCollection object:
http://mapguide.osgeo.org/files/mapguide/docs/webapi/dc/df0/class_mg_layer_collection.htm
Regards, Kenneth Skovhede, GEOGRAF A/S
gingerbbm skrev:
> I don't mind at all; thanks for doing it.
> Just as an addendum to this discussion about adjusting map configuration
> dynamically, my next challenge is to update the feature class of a layer
> based upon the current map centre point. In other words, as the user drags
> the map around, at certain positions the underlying database table for one
> of my layers needs to change.
> Back towards the start of this thread, one of the suggestions for adjusting
> the intial map view was:
> "2. modify the ajaxviewer"
> Is this my only option to set a layer's feature class dynamically? My
> current thinking is to override specific tools (such as pan) to call a
> custom PHP which ultimately redirects to the Ajax Viewer.
> Any thoughts on this?
