[mapguide-users] How to use Java (JSP) development with IIS
Scott Hameister scotth at mpowerinnovations.com
Sun Sep 7 10:40:07 EDT 2008
Just goto control panel where you can remove repair installs...and you can modify your install to add Java to your server extensions install...do not remove php you'll  still need it for admin etc....we use coldfusion on Java in windows...it works great and is very fast.
-----Original Message-----
To: mapguide-users at lists.osgeo.org
Sent: 9/6/08 8:51 PM
Subject: [mapguide-users] How to use Java (JSP) development with IIS
For MapGuide, I want to use IIS server v6.0 (Windows 2003), but instead of
using PHP or .NET, I want to use Java (JSP) as my development language. I
noticed that for IIS, the "default" languages are only PHP or .NET. How do I
enable it for Java (tomcat, etc) as well?
thanks very much your help.
View this message in context: http://n2.nabble.com/How-to-use-Java-%28JSP%29-development-with-IIS-tp950716p950716.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
