[mapguide-users] postrgres connection properties not accessable
Zac Spitzer
zac.spitzer at gmail.com
Tue Sep 16 02:32:52 EDT 2008
you will need to check which depenancies for the fdo provider are
missing, which will
involve using depends on win32 or ldd on linux..
which postgres libraries did you install?
z
On Tue, Sep 16, 2008 at 4:25 PM, andreas mutota <amutota2002 at yahoo.com> wrote:
> Hi all, I would like to get connected to postgres DB but all I get is that
> the connection properties are not active/enabled. If I hit 'Test
> connection' I get the following error:An exception occurred in FDO
> component.
> Unable to load the FDO Provider: The specified module could not be found.
> Anyone with an idea of what I can do to resolve this problem please help.
> Thanks in advance.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
