[mapguide-users] postrgres connection properties not accessable
lolob azzam_wahab at hotmail.com
Tue Sep 16 04:00:18 EDT 2008
Hello zspitzer,
I downloaded version 3.3 and copied all the dependencies needed. I used
Dependency Walker to check them. Please look at my screenshot. I tried with
both ODBC and Fdo PostGis. Unfortunately only ODBC works.
http://www.nabble.com/file/p19507098/case1.jpg
http://www.nabble.com/file/p19507098/case2.jpg
Any idea?.
-lolob
zspitzer wrote:
> you will need to check which depenancies for the fdo provider are
> missing, which will
> involve using depends on win32 or ldd on linux..
> which postgres libraries did you install?
> z
> On Tue, Sep 16, 2008 at 4:25 PM, andreas mutota <amutota2002 at yahoo.com>
> wrote:
>> Hi all, I would like to get connected to postgres DB but all I get is
>> that
>> the connection properties are not active/enabled. If  I hit 'Test
>> connection' I get the following error:An exception occurred in FDO
>> component.
>> Unable to load the FDO Provider: The specified module could not be found.
>> Anyone with an idea of what I can do to resolve this problem please help.
>> Thanks in advance.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
View this message in context: http://www.nabble.com/postrgres-connection-properties-not-accessable-tp19506080p19507098.html
