[mapguide-users] postrgres connection properties not accessable
lolob azzam_wahab at hotmail.com
Tue Sep 16 04:33:40 EDT 2008
I solved it. I forgot to put 'public' for the DataStore. I hit the test
connection and okay. But when I'm trying to fetch the coordinate system or
preview the connection data. My Mapguide Server crash.
-lolob
lolob wrote:
> Hello zspitzer,
> I downloaded version 3.3 and copied all the dependencies needed. I used
> Dependency Walker to check them. Please look at my screenshot. I tried
> with both ODBC and Fdo PostGis. Unfortunately only ODBC works.
>  http://www.nabble.com/file/p19507098/case1.jpg
>  http://www.nabble.com/file/p19507098/case2.jpg
> Any idea?.
> -lolob
> zspitzer wrote:
>> you will need to check which depenancies for the fdo provider are
>> missing, which will
>> involve using depends on win32 or ldd on linux..
>> which postgres libraries did you install?
>> z
>> On Tue, Sep 16, 2008 at 4:25 PM, andreas mutota <amutota2002 at yahoo.com>
>> wrote:
>>> Hi all, I would like to get connected to postgres DB but all I get is
>>> that
>>> the connection properties are not active/enabled. If  I hit 'Test
>>> connection' I get the following error:An exception occurred in FDO
>>> component.
>>> Unable to load the FDO Provider: The specified module could not be
>>> found.
>>> Anyone with an idea of what I can do to resolve this problem please
>>> help.
>>> Thanks in advance.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
View this message in context: http://www.nabble.com/postrgres-connection-properties-not-accessable-tp19506080p19507582.html
