[mapguide-users] PostGIS binaries
Nandorov
nandorov at gmail.com
Thu Sep 18 11:36:59 EDT 2008
Thank you Jackie, i fixed my problem.
Jackie C. Ng wrote:
> 2 things I notice:
> 1) MG 2009 uses FDO 3.3, yet your providers.xml entry uses 3.2 binaries.
> 2) I believe that PostGIS provider also needs to have PostGIS and
> PostgreSQL
> binaries in the same path as the provider. See:
> http://trac.osgeo.org/fdo/wiki/FdoPostGISNotes
> - Jackie
> Moog wrote:
>> Hi,
>> i downloaded PostGIS binaries from
>> http://www.geomapgis.com/web/geomap-group/fdo/index.html
>> put them into C:\Program
>> Files\Autodesk\MapGuideEnterprise2009\Server\Bin\Fdo and modify
>> providers.xml adding
>> <FeatureProvider>
>> <Name>OSGeo.PostGIS.3.2</Name>
>> <DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
>> <Description>FDO Provider for PostGIS</Description>
>> <IsManaged>False</IsManaged>
>> <Version>3.2.0.0</Version>
>> <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
>> <LibraryPath>.\PostGISProvider.dll</LibraryPath>
>> </FeatureProvider>
>> i use dependency walker i got the following warning for
>> PostGISProvider.dll
>> Warning: At least one module has an unresolved import due to a missing
>> export function in a delay-load dependent module.
>> i can't see PostGIS FDO provider while i'm trying to make a data
>> connection
>> at mapguide studio 2009. Any sugest?
>> Best regards and thanks for your time,
>> Fernando.
>> View this message in context:
>> http://www.nabble.com/PostGIS-binaries-tp19541494p19541494.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/PostGIS-binaries-tp1096595p1096850.html
> http://themapguyde.blogspot.com
> http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/PostGIS-binaries-tp19541494p19555698.html
