[mapguide-users] MgDateTimeException
Suja Sudhan
suja.sudhan at atkinsglobal.com
Thu Sep 18 16:26:11 EDT 2008
Yes Jackie, but guess I can check for null values only after populating the
feature reader. But the error is thrown while populating the feature reader
itself.
Jackie C. Ng wrote:
> You could be onto something here. A recent change in the API (?) requires
> that if you call any MgFeatureReader::GetXXX() method, that you should
> call IsNull() on that property first, and then call the GetXXX() method if
> IsNull() returns false. Otherwise an exception will be thrown if the
> property in question is null.
> - Jackie
> Suja Sudhan wrote:
>> Thanks for your response Jackie.
>> I later found that if a datetime field is null for a feature, then the
>> error is thrown. Error is not thrown when the field has a valid value and
>> the feature reader is populated without any issue. I am using MGE2008.
>> Guess, null datetime values aren't accepted. Can someone confirm this
>> please?
>> Thanks again.
>> Suja
>> Jackie C. Ng wrote:
>>> It could be a bad filter string, what is the value of selectstring when
>>> you
>>> pass it to the MgFeatureQueryOptions object?
>>> - Jackie
>>> Suja Sudhan wrote:
>>>> Hello All,
>>>> I am trying to get all the attributes of a layer and below is my code
>>>> to
>>>> do
>>>> it. It works well for most of the layers but throws MgDateTimeException
>>>> for
>>>> couple of layers at the line of code where the feature reader is
>>>> populated
>>>> (pl see code below). What should be causing this, anything to do with
>>>> the
>>>> data?
>>>> MgMap map = new MgMap();
>>>> map.Open(resService, mapName);
>>>> //get the layer for which the attributes have to be got
>>>> MgLayerBase layer = map.GetLayers().GetItem(layerName);
>>>> //get the layer class name
>>>> string layerClassName = layer.GetFeatureClassName();
>>>> MgSelection selection = new MgSelection();
>>>> //generate a selection string
>>>> string selectstring = selection.GenerateFilter(layer,
>>>> layerClassName).ToString();
>>>> //set the query option required for the reader to populate
>>>> MgFeatureQueryOptions featQueryOption = new
>>>> MgFeatureQueryOptions();
>>>> featQueryOption.SetFilter(selectstring);
>>>> //get the layer resource id
>>>> MgResourceIdentifier resId = new
>>>> MgResourceIdentifier(layer.GetFeatureSourceId()); ;
>>>> //populate feature reader
>>>> MgFeatureReader reader = featService.SelectFeatures(resId,
>>>> layerClassName, featQueryOption);
>>>> The code throws MgDateTimeException (message: A date and/or time
>>>> exception
>>>> occurred.) at the above line.
>>>> Thanks,
>>>> Suja
>>>> View this message in context:
>>>> http://www.nabble.com/MgDateTimeException-tp19465653p19465653.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> http://n2.nabble.com/MgDateTimeException-tp1086509p1096857.html
>>> http://themapguyde.blogspot.com
>>> http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/MgDateTimeException-tp19465653p19561028.html
