[mapguide-users] new Jx.PanelManager
Paul Spencer
pagameba at gmail.com
Fri Sep 19 08:47:03 EDT 2008
Hi Rock,
Jason is correct. The trunk version of Fusion is not stable at
present and won't work with the mapguide templates at all until they
are overhauled for the new Jx API and skin structure.
I am hoping that the mapguide templates will be updated in due course,
especially as Autodesk was kind enough to provide funding for many of
the changes in the trunk version of Fusion.
Once things are moderately stable, I'll be emailing the lists to
enlist testers, but before that you will need pretty thick skin (pun
intended) to start playing with the trunk version :)
Cheers
Paul
On 18-Sep-08, at 5:12 PM, Rock Beans wrote:
> The ultimate goal is to make MapGuide 2009 Enterprise work with Fusion
> and Firefox 3. The end result of this is pretty much banging my head,
> burning out... again and switching back to the basic viewer until
> Fusion works it's issues out. Thanks for the links and very prompt
> response!
> On Thu, Sep 18, 2008 at 4:08 PM, Jason Birch
> <Jason.Birch at nanaimo.ca> wrote:
>> If you are following Fusion trunk, you'll have to do a lot of work to
>> get your MapGuide templates working; Paul has committed a new
>> version of
>> Jx that is considerably different, and as part of this modified the
>> widget architecture. See messages below...
>> Widget Architecture:
>> http://trac.osgeo.org/fusion/ticket/117
>> Jx API Changes:
>> http://lists.osgeo.org/pipermail/fusion-dev/2008-September/
>> 000136.html
>> Other 2.0/trunk changes:
>> 000132.html
>> If you're following the 1.1 branch of Fusion I think you should be
>> OK,
>> but will need to apply some changes here:
>> http://trac.osgeo.org/mapguide/ticket/676
>> I'd suggesting asking questions about Jx on the Fusion mailing lists.
>> http://trac.osgeo.org/fusion/wiki/MailingLists
>> Jason
>> -----Original Message-----
>> From: Rock Beans
>> Subject: [mapguide-users] new Jx.PanelManager
>> Has new Jx.PanelManager been removed from the new SVN of Fusion. My
>> older MapGuide templates are not working.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
