[mapguide-users] new Jx.PanelManager
Rock Beans
rockbeans at gmail.com
Fri Sep 19 12:27:12 EDT 2008
Is this one of the reasons why MapGuide 2.0.2 was pulled fromt he
download server?
On Fri, Sep 19, 2008 at 7:47 AM, Paul Spencer <pagameba at gmail.com> wrote:
> Hi Rock,
> Jason is correct. The trunk version of Fusion is not stable at present and
> won't work with the mapguide templates at all until they are overhauled for
> the new Jx API and skin structure.
> I am hoping that the mapguide templates will be updated in due course,
> especially as Autodesk was kind enough to provide funding for many of the
> changes in the trunk version of Fusion.
> Once things are moderately stable, I'll be emailing the lists to enlist
> testers, but before that you will need pretty thick skin (pun intended) to
> start playing with the trunk version :)
> Cheers
> Paul
> On 18-Sep-08, at 5:12 PM, Rock Beans wrote:
>> The ultimate goal is to make MapGuide 2009 Enterprise work with Fusion
>> and Firefox 3. The end result of this is pretty much banging my head,
>> burning out... again and switching back to the basic viewer until
>> Fusion works it's issues out. Thanks for the links and very prompt
>> response!
>> On Thu, Sep 18, 2008 at 4:08 PM, Jason Birch <Jason.Birch at nanaimo.ca>
>> wrote:
>>> If you are following Fusion trunk, you'll have to do a lot of work to
>>> get your MapGuide templates working; Paul has committed a new version of
>>> Jx that is considerably different, and as part of this modified the
>>> widget architecture. See messages below...
>>> Widget Architecture:
>>> http://trac.osgeo.org/fusion/ticket/117
>>> Jx API Changes:
>>> http://lists.osgeo.org/pipermail/fusion-dev/2008-September/000136.html
>>> Other 2.0/trunk changes:
>>> http://lists.osgeo.org/pipermail/fusion-dev/2008-September/000132.html
>>> If you're following the 1.1 branch of Fusion I think you should be OK,
>>> but will need to apply some changes here:
>>> http://trac.osgeo.org/mapguide/ticket/676
>>> I'd suggesting asking questions about Jx on the Fusion mailing lists.
>>> http://trac.osgeo.org/fusion/wiki/MailingLists
>>> Jason
>>> -----Original Message-----
>>> From: Rock Beans
>>> Subject: [mapguide-users] new Jx.PanelManager
>>> Has new Jx.PanelManager been removed from the new SVN of Fusion. My
>>> older MapGuide templates are not working.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
