[mapguide-users] new Jx.PanelManager
Paul Spencer pagameba at gmail.com
Fri Sep 19 13:41:29 EDT 2008
I don't think so.
On 19-Sep-08, at 12:27 PM, Rock Beans wrote:
> Is this one of the reasons why MapGuide 2.0.2 was pulled fromt he
> download server?
> On Fri, Sep 19, 2008 at 7:47 AM, Paul Spencer <pagameba at gmail.com>
> wrote:
>> Hi Rock,
>> Jason is correct.  The trunk version of Fusion is not stable at
>> present and
>> won't work with the mapguide templates at all until they are
>> overhauled for
>> the new Jx API and skin structure.
>> I am hoping that the mapguide templates will be updated in due
>> course,
>> especially as Autodesk was kind enough to provide funding for many
>> of the
>> changes in the trunk version of Fusion.
>> Once things are moderately stable, I'll be emailing the lists to
>> enlist
>> testers, but before that you will need pretty thick skin (pun
>> intended) to
>> start playing with the trunk version :)
>> Cheers
>> Paul
>> On 18-Sep-08, at 5:12 PM, Rock Beans wrote:
>>> The ultimate goal is to make MapGuide 2009 Enterprise work with
>>> Fusion
>>> and Firefox 3. The end result of this is pretty much banging my
>>> head,
>>> burning out... again and switching back to the basic viewer until
>>> Fusion works it's issues out. Thanks for the links and very prompt
>>> response!
>>> On Thu, Sep 18, 2008 at 4:08 PM, Jason Birch
>>> <Jason.Birch at nanaimo.ca>
>>> wrote:
>>>> If you are following Fusion trunk, you'll have to do a lot of
>>>> work to
>>>> get your MapGuide templates working; Paul has committed a new
>>>> version of
>>>> Jx that is considerably different, and as part of this modified the
>>>> widget architecture.  See messages below...
>>>> Widget Architecture:
>>>> http://trac.osgeo.org/fusion/ticket/117
>>>> Jx API Changes:
>>>> http://lists.osgeo.org/pipermail/fusion-dev/2008-September/000136.html
>>>> Other 2.0/trunk changes:
>>>> http://lists.osgeo.org/pipermail/fusion-dev/2008-September/000132.html
>>>> If you're following the 1.1 branch of Fusion I think you should
>>>> be OK,
>>>> but will need to apply some changes here:
>>>> http://trac.osgeo.org/mapguide/ticket/676
>>>> I'd suggesting asking questions about Jx on the Fusion mailing
>>>> lists.
>>>> http://trac.osgeo.org/fusion/wiki/MailingLists
>>>> Jason
>>>> -----Original Message-----
>>>> From: Rock Beans
>>>> Subject: [mapguide-users] new Jx.PanelManager
>>>> Has new Jx.PanelManager been removed from the new SVN of Fusion. My
>>>> older MapGuide templates are not working.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
