[mapguide-users] the Overview map widgets questions
brianlee
pengxianghepipi at 163.com
Thu Sep 25 22:45:33 EDT 2008
hey, Andy
Should I port the php script of fusion release into Asp.net to use fusion
template?
Could you share the sample working code with me?
thanks
Andy Morsell wrote:
> The overview map on that site is just the out-of-the-box overview map of a
> Fusion template. I did not do anything special there.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of brianlee
> Sent: Thursday, September 25, 2008 7:17 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] the Overview map widgets questions
> hello,
> I need to implements an overview map widget using c # with ASP.net API
> of
> MapGuide 2.0.
> Just look like Andy Morsell has done at
> http://mapguide.spatialgis.com/mapguide/spokanemaps/ SpatialGIS.com .
> Should I create an overview map weblayout or some other methods?
> Could Andy or somebody else point me the right direction to do?
> thanks
> brian lee
> http://www.nabble.com/the-Overview-map-widgets-questions-tp19670459p19670459
> .html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/the-Overview-map-widgets-questions-tp19670459p19681660.html
