[mapguide-users] the Overview map widgets questions
Andy Morsell
amorsell at spatialgis.com
Thu Sep 25 23:47:01 EDT 2008
Fusion is written only in PHP, but you can still interface with Fusion and
the underlying MGOS API via ASP.NET if you want. There really is no sample
code on my end, it's just using the default Slate Fusion template and has
been somewhat modified via Autodesk MapGuide Studio 2009.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of brianlee
Sent: Thursday, September 25, 2008 7:46 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] the Overview map widgets questions
hey, Andy
Should I port the php script of fusion release into Asp.net to use fusion
template?
Could you share the sample working code with me?
thanks
Andy Morsell wrote:
> The overview map on that site is just the out-of-the-box overview map of a
> Fusion template. I did not do anything special there.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Thursday, September 25, 2008 7:17 AM
> Subject: [mapguide-users] the Overview map widgets questions
> hello,
> I need to implements an overview map widget using c # with ASP.net API
> of
> MapGuide 2.0.
> Just look like Andy Morsell has done at
> http://mapguide.spatialgis.com/mapguide/spokanemaps/ SpatialGIS.com .
> Should I create an overview map weblayout or some other methods?
> Could Andy or somebody else point me the right direction to do?
> thanks
> brian lee
http://www.nabble.com/the-Overview-map-widgets-questions-tp19670459p19670459
> .html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://www.nabble.com/the-Overview-map-widgets-questions-tp19670459p19681660
.html
