[mapguide-users] .NET Fusion
Jackie C. Ng jumpinjackie at gmail.com
Tue Sep 30 08:11:00 EDT 2008
There hasn't really been any effort to port the fusion widget backends to
asp.net because when installing MapGuide, even if you choose the .net
configuration, PHP will still be installed as it is required by the site
administrator component.
So choosing PHP as the language of choice is a safe decision (or maybe the
Fusion developers were better with PHP, I dunno, I'm just guessing the
reasons here)
- Jackie
brianlee wrote:
> How is the integration .Net with fusion going?
> have you port the fusion\MapGuide\php into fusion\MapGuide\DotNet by C# or
> Vb.net?
> what's your configuration of your mgos app?
> please kindly provide some infomation about get fusion running on .net
> platform.
> thanks
> Berdel, Brian wrote:
>> You are correct about the widgets and .NET, I actually started
>> converting them a while back, but I haven't been able to dedicate enough
>> time to it...
>> And yes I am using the task pane, and the feature reader works fine for
>> accessing a layer by layer name and session variable, but if I try to
>> open a map via the name it always tells me it cannot find...One other
>> question I would have about fusion is how to access the mapframe from
>> the task pane...
>> parent.parent.mapframe does not exist.  I saw the documentation about
>> building a fusion template, but I a haven't really been able to get a
>> handle on the structure as it relates to the regular AJAX viewer.
>> Thanks,
>> Brian  Berdel
>> McMahon Associates, Inc.
>> p: 215.283.9444
>> www.mcmtrans.com
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
>> Sent: Thursday, April 17, 2008 2:20 PM
>> To: MapGuide Users Mail List
>> Subject: RE: [mapguide-users] .NET Fusion
>> As far as I know, Fusion works with a .Net install, but you can't write
>> widgets in .Net unless you re-write the entire widget stack in this
>> language.  This is something that I'd be interested in seeing, but only
>> from an academic perspective. :)
>> Brian, how are you integrating .Net into Fusion?  With a task pane
>> application?  I wonder if there is a JavaScript function that returns
>> the map ID?
>> Jason
>> From: Berdel, Brian
>> Mike it actually does because I am able to use the featurereader...I
>> just cannot open a map.  Anyone know how to get the ID?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/.NET-Fusion-tp16722611p19740813.html
