[mapguide-users] .NET Fusion
Zac Spitzer
zac.spitzer at gmail.com
Tue Sep 30 08:44:46 EDT 2008
php is cross platform too... mono aside...
On Tue, Sep 30, 2008 at 10:11 PM, Jackie C. Ng <jumpinjackie at gmail.com> wrote:
> There hasn't really been any effort to port the fusion widget backends to
> asp.net because when installing MapGuide, even if you choose the .net
> configuration, PHP will still be installed as it is required by the site
> administrator component.
> So choosing PHP as the language of choice is a safe decision (or maybe the
> Fusion developers were better with PHP, I dunno, I'm just guessing the
> reasons here)
> - Jackie
> brianlee wrote:
>> How is the integration .Net with fusion going?
>> have you port the fusion\MapGuide\php into fusion\MapGuide\DotNet by C# or
>> Vb.net?
>> what's your configuration of your mgos app?
>> please kindly provide some infomation about get fusion running on .net
>> platform.
>> thanks
>> Berdel, Brian wrote:
>>> You are correct about the widgets and .NET, I actually started
>>> converting them a while back, but I haven't been able to dedicate enough
>>> time to it...
>>> And yes I am using the task pane, and the feature reader works fine for
>>> accessing a layer by layer name and session variable, but if I try to
>>> open a map via the name it always tells me it cannot find...One other
>>> question I would have about fusion is how to access the mapframe from
>>> the task pane...
>>> parent.parent.mapframe does not exist. I saw the documentation about
>>> building a fusion template, but I a haven't really been able to get a
>>> handle on the structure as it relates to the regular AJAX viewer.
>>> Thanks,
>>> Brian Berdel
>>> McMahon Associates, Inc.
>>> p: 215.283.9444
>>> www.mcmtrans.com
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
>>> Sent: Thursday, April 17, 2008 2:20 PM
>>> To: MapGuide Users Mail List
>>> Subject: RE: [mapguide-users] .NET Fusion
>>> As far as I know, Fusion works with a .Net install, but you can't write
>>> widgets in .Net unless you re-write the entire widget stack in this
>>> language. This is something that I'd be interested in seeing, but only
>>> from an academic perspective. :)
>>> Brian, how are you integrating .Net into Fusion? With a task pane
>>> application? I wonder if there is a JavaScript function that returns
>>> the map ID?
>>> Jason
>>> From: Berdel, Brian
>>> Mike it actually does because I am able to use the featurereader...I
>>> just cannot open a map. Anyone know how to get the ID?
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://themapguyde.blogspot.com
> http://www.linkedin.com/in/jackieng
> View this message in context: http://www.nabble.com/.NET-Fusion-tp16722611p19740813.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
