[mapguide-users] Maestro Login failed
SandraH sahoerne at web.de
Wed Apr 1 06:45:48 EDT 2009
Hello,
I installed MgServer and MgWebServerExtensions on Windows Server 2003. I can open the Webstudio, Site Administrator and MapGuide Agent.
I tried to login with Maestro, which I installed on an Windows XP PC. I used the same entries for Server, Username and Password as I used with MapGuide Open Source Webstudio. But the login with Maestro failed.
I recieved the following message:
Faild to log on because: Failed to connect, please check network connection and login information
Extended error info: Failed to connect, perhaps session is expired?
Extended error info: Der Remoteserver hat einen Fehler zurückgegeben:(401)Nicht autorisiert.
Any ideas? The Firewall?
Thanks,
Sandra
View this message in context: http://n2.nabble.com/Maestro-Login-failed-tp2568345p2568345.html
