[mapguide-users] Maestro Login failed
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Apr 2 02:50:21 EDT 2009
Can you get a subcode for the error number?
http://support.microsoft.com/kb/907273
What url do you use?
Regards, Kenneth Skovhede, GEOGRAF A/S
SandraH skrev:
> Hello,
> I installed MgServer and MgWebServerExtensions on Windows Server 2003. I can open the Webstudio, Site Administrator and MapGuide Agent.
> I tried to login with Maestro, which I installed on an Windows XP PC. I used the same entries for Server, Username and Password as I used with MapGuide Open Source Webstudio. But the login with Maestro failed.
> I recieved the following message:
> Faild to log on because: Failed to connect, please check network connection and login information
> Extended error info: Failed to connect, perhaps session is expired?
> Extended error info: Der Remoteserver hat einen Fehler zurückgegeben:(401)Nicht autorisiert.
> Any ideas? The Firewall?
> Thanks,
> Sandra
