[mapguide-users] Mapguide without Apache
alucas
alucas at svl.es
Wed Apr 1 12:01:24 EDT 2009
I'm working with eclipse as Development environmet in my local machine. Every developer has his own webserver extensions installed and configure an eclipse server project pointing to the mapguide tomcat installation. The database and mapserver service are installed in another server. This way, every developer executes his own application copy on his local tomcat and you can integrate svn (or another). Something like this is the configuration are you searching for?
Regards.
Hi all, it is posible use Mapguide without Apache, only with Tomcat?. We are
triying but don´t see the map, only the rest of controls.
Thanks.
# michogar
# Analista Programador SIG
# GNU/Linux Counter 462666
Una visión personal:
http://michogar.blogspot.com
El dia a dia:
http://twitter.com/michogar
"Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
peor... Si lo reproduces del derecho... ¡Se instala!."
"It has a legend that if you play an original Windows Vista DVD backwards to
hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
you play it right ... It installs!.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Mapguide-without-Apache-tp2568654p2569909.html
