[mapguide-users] Mapguide without Apache
Zac Spitzer
zac.spitzer at gmail.com
Wed Apr 8 04:00:23 EDT 2009
going down this track we should consider nginx or lighthttpd as they are much
faster than apache, especially when it comes to serving static stuff like tiles
z
On Wed, Apr 8, 2009 at 5:57 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Is this actually a feasible solution that is usable in a production environment? If so, I am willing to make a pure, tomcat-only configuration for the installer (but if so, this configuration won't make it for 2.1)
> - Jackie
> Hello,
> Yes, you can but you need to do some steps.
> 1. Modify www/WEB-INF/web.xml to add cgi support:
> <servlet>
> <servlet-name>cgi</servlet-name>
> <servlet-class>org.apache.catalina.servlets.CGIServlet</servlet-class>
> <init-param>
> <param-name>debug</param-name>
> <param-value>6</param-value>
> </init-param>
> <init-param>
> <param-name>cgiPathPrefix</param-name>
> <param-value></param-value>
> </init-param>
> <init-param>
> <param-name>executable</param-name>
> </init-param>
> <!--Nota: si no le paso las variables de entorno intenta descargarse el resultado de la ejecución del programa -->
> <init-param>
> <param-name>passShellEnvironment</param-name>
> <param-value>true</param-value>
> </init-param>
> <load-on-startup>5</load-on-startup>
> </servlet>
> <servlet-mapping>
> <url-pattern>*.fcgi</url-pattern>
> </servlet-mapping>
> 2. rename www/mapagent.fcgi to mapagent.fcgi2
> 3. make a copy of maagent.exe to mapagent.fcgi
> 4. rename to jar servlet-api
> Hope this helps.
> Hi all, it is posible use Mapguide without Apache, only with Tomcat?. We are
> triying but don´t see the map, only the rest of controls.
> Thanks.
> # michogar
> # Analista Programador SIG
> # GNU/Linux Counter 462666
> Una visión personal:
> http://michogar.blogspot.com
> El dia a dia:
> http://twitter.com/michogar
> "Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
> revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
> peor... Si lo reproduces del derecho... ¡Se instala!."
> "It has a legend that if you play an original Windows Vista DVD backwards to
> hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
> you play it right ... It installs!.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> View this message in context: http://n2.nabble.com/Mapguide-without-Apache-tp2568654p2603733.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
