[mapguide-users] Rendering defect?
Dave Wilson dave.wilson at autodesk.com
Wed Apr 1 13:17:44 EDT 2009
Ok that makes sense. At least the user can test your option.
I still think an enhancement request should be logged for this as I've seen this mentioned before. I recall discussing the same question with Bob Bray about 2+ years ago.
I'm not sure users really expect to see the border and I'm guessing it's probably not worthwhile to make this a configurable option. I think we should look at changing the default behavior to not display the border.
I can also log an internal defect on this to.
Regards,
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Wednesday, April 01, 2009 11:12 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Rendering defect?
If the polygon is clipped geometrically before rendering, like we see in the screenshot, there will be a border. If it is not clipped geometrically before rendering, like when one uses the RenderMap API, then there will not be the artifact we see. I understand that it is undesirable to see the border lines even if the polygon is clipped geometrically -- however this is not possible without a code change, while the suggestion I gave can potentially remove the problem without any code changes.
Traian
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Wednesday, April 01, 2009 1:01 PM
I don't think the issue is so much about the clipping, it's about the false border that's introduced. Users don't want a false border on the clipped polygon.
Dave
Sent: Wednesday, April 01, 2009 10:41 AM
To: 'MapGuide Users Mail List'
There are APIs in the rendering service for both clipped and unclipped rendering. RenderDynamicOverlay clips, while RenderMap doesn't. I'm not sure which one Fusion uses though. You can try manually issuing a RenderMap to see if you get the result you want. Using the un-clipped rendering carries a performance penalty.
Traian
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andreas Morf
Sent: Wednesday, April 01, 2009 12:14 PM
Exactly, that's what I wanted to express - I'm not an native speaker
I want to be able to switch off that current behavior of MG
Andreas
> Sent: Wednesday, April 01, 2009 5:52 PM
> To clarify,
> Are you saying that around the borders of the frame an edge is
> generated for the polygon even though the polygon extends past the
> visible region of the frame suggesting to the user that the polygon is
> completely visible when it's actually not?
> I would argue this is a design deficiency, but that is how it was
> implemented.
> I would log an enhancement trac ticket asking that polygons not be
> clipped by the map frame.
> Regards,
> Dave
> Sent: Wednesday, April 01, 2009 9:21 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Rendering defect?
> There is a strange behaviour of MGOS 2.0.2 when rendering polygons with
> a
> <CompositeTypeStyle>: clipped edges of the polygons (which may be
> borders of the map in a fusion-viewers) are also drawn according the
> instructions in the <LineUsage> of the <SimpleSymbolDefinition>.
> In my opinion this is not a correct behavior of the rendering service!
> Attached there is a small sample rendered image.
> Is this a case for a ticket?
> Any comments?
> mapguide-users mailing list
