[mapguide-users] Get Identity Properties
Jamo
adam.jamison at portbris.com.au
Thu Apr 2 02:37:57 EDT 2009
Incase anyone is interested I figured it out... I no longer have to hard code what the identity property is .
the following will read the feature reader and return the identity property allowing me now to create more dynamic commands :)
I haven't filled in all the select cases as I'm not sure whats what there.
while (newFeatReader.ReadNext())
MgPropertyCollection idProps = new MgPropertyCollection();
MgResourceIdentifier myRes = new MgResourceIdentifier(currentLayer.GetFeatureSourceId());
foreach (MgPropertyDefinition IdPropDef in newFeatReader.GetClassDefinition().GetIdentityProperties())
switch (newFeatReader.GetPropertyType(IdPropDef.Name))
case 1:
// Response.Write("1");
break;
case 2:
// Response.Write("2");
break;
case 3:
// Response.Write("3");
break;
case 4:
// Response.Write("4");
break;
case 5:
// Response.Write("5");
break;
case 6:
// Response.Write("6");
break;
case 7:
idProps.Add(new MgInt32Property(IdPropDef.Name, newFeatReader.GetInt32(IdPropDef.Name)));
// Response.Write("7");
break;
case 8:
// Response.Write("8");
break;
case 9:
// Response.Write("9");
break;
default:
// Response.Write("no valid type");
break;
MgSelection sel = new MgSelection();
sel.AddFeatureIds(currentLayer, currentClassName, idProps);
String selText = EscapeForHtml(sel.ToXml());
//do additional stuff with feature here....
View this message in context: http://n2.nabble.com/Get-Identity-Properties-tp2567438p2573602.html
