[mapguide-users] Get Identity Properties
Andy Morsell amorsell at spatialgis.com
Thu Apr 2 12:11:10 EDT 2009
There's also some similar code in several places in the viewer files (both
AJAX and Fusion) and some of the sample applications.  This is from
www/mapviewernet/search.aspx.:
	String prop = (String)resProps[i];
                        int propType = features.GetPropertyType(prop);
                        String val = "";
                        switch (propType)
                            case MgPropertyType.Boolean:
                                val = features.GetBoolean(prop) ? "True" :
"False";
                                break;
                            case MgPropertyType.Single:
                                val = features.GetSingle(prop).ToString();
                                break;
                            case MgPropertyType.Double:
                                val = features.GetDouble(prop).ToString();
                                break;
                            case MgPropertyType.Int16:
                                val = features.GetInt16(prop).ToString();
                                break;
                            case MgPropertyType.Int32:
                                val = features.GetInt32(prop).ToString();
                                break;
                            case MgPropertyType.Int64:
                                val = features.GetInt64(prop).ToString();
                                break;
                            case MgPropertyType.String:
                                val = features.GetString(prop);
                                break;
                            case MgPropertyType.DateTime:
                                val = features.GetDateTime(prop).ToString();
                                break;
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jamo
Sent: Wednesday, April 01, 2009 11:38 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Get Identity Properties
Incase anyone is interested I figured it out... I no longer have to hard
code what the identity property is .
the following will read the feature reader and return the identity property
allowing me now to create more dynamic commands :)
I haven't filled in all the select cases as I'm not sure whats what there.
      while (newFeatReader.ReadNext())
        MgPropertyCollection idProps = new MgPropertyCollection();
        MgResourceIdentifier myRes = new
MgResourceIdentifier(currentLayer.GetFeatureSourceId());
        foreach (MgPropertyDefinition IdPropDef in
newFeatReader.GetClassDefinition().GetIdentityProperties())
            switch (newFeatReader.GetPropertyType(IdPropDef.Name))
              case 1:
             //   Response.Write("1");
                break;
              case 2:
             //   Response.Write("2");
                break;
              case 3:
             //   Response.Write("3");
                break;
              case 4:
              //  Response.Write("4");
                break;
              case 5:
             //   Response.Write("5");
                break;
              case 6:
              //  Response.Write("6");
                break;
              case 7:
                idProps.Add(new MgInt32Property(IdPropDef.Name,
newFeatReader.GetInt32(IdPropDef.Name)));
               // Response.Write("7");
                break;
              case 8:
              //  Response.Write("8");
                break;
              case 9:
              //  Response.Write("9");
                break;
              default:
              //  Response.Write("no valid type");
                break;
        MgSelection sel = new MgSelection();
        sel.AddFeatureIds(currentLayer, currentClassName, idProps);
        String selText = EscapeForHtml(sel.ToXml());
//do additional stuff with feature here....
View this message in context:
http://n2.nabble.com/Get-Identity-Properties-tp2567438p2573602.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
