[mapguide-users] Can't create layer using MySQL feature source
Stefan Dalakov
s.dalakov at mapware.net
Mon Apr 6 10:48:14 EDT 2009
Hi Manel,
Here is a layerDefinition that works for me.
Have you specified Coordinate-System-Overrides ?
Stefan Dalakov
<?xml version="1.0" encoding="UTF-8" ?>
- <#> <LayerDefinition
xmlns:xsi="*http://www.w3.org/2001/XMLSchema-instance*"
xsi:noNamespaceSchemaLocation="*LayerDefinition-1.1.0.xsd*"
version="*1.1.0*">
- <#> <VectorLayerDefinition>
<ResourceId>Library://mysql_ds.FeatureSource</ResourceId>
<FeatureName>Fdotechnop_mg:links</FeatureName>
<FeatureNameType>FeatureClass</FeatureNameType>
- <#> <PropertyMapping>
<Name>LAYER</Name>
<Value>LAYER</Value>
</PropertyMapping>
<Name>LENGTH</Name>
<Value>LENGTH</Value>
</PropertyMapping>
<Geometry>ogc_geom</Geometry>
- <#> <VectorScaleRange>
- <#> <PointTypeStyle>
<DisplayAsText>false</DisplayAsText>
<AllowOverpost>false</AllowOverpost>
- <#> <PointRule>
<LegendLabel />
</PointRule>
</PointTypeStyle>
- <#> <LineTypeStyle>
- <#> <LineRule>
<LegendLabel>'Main Pipe'</LegendLabel>
<Filter>"LAYER" = 'Main Pipe'</Filter>
- <#> <LineSymbolization2D>
<LineStyle>Solid</LineStyle>
<Thickness>2</Thickness>
<Color>FF000000</Color>
<Unit>Points</Unit>
<SizeContext>DeviceUnits</SizeContext>
</LineSymbolization2D>
</LineRule>
- <#> <LineRule>
<LegendLabel>'Pipeline'</LegendLabel>
<Filter>"LAYER" = 'Pipeline'</Filter>
<Color>FF000080</Color>
<Unit>Points</Unit>
</LineRule>
- <#> <LineRule>
<LegendLabel />
<Thickness>0.0</Thickness>
<Color>ff000000</Color>
<Unit>Centimeters</Unit>
</LineRule>
</LineTypeStyle>
- <#> <AreaTypeStyle>
- <#> <AreaRule>
<LegendLabel />
- <#> <AreaSymbolization2D>
- <#> <Fill>
<FillPattern>Solid</FillPattern>
<ForegroundColor>ffffffff</ForegroundColor>
<BackgroundColor>ff000000</BackgroundColor>
</Fill>
- <#> <Stroke>
</Stroke>
</AreaSymbolization2D>
</AreaRule>
</AreaTypeStyle>
</VectorScaleRange>
</VectorLayerDefinition>
</LayerDefinition>
Manel Gimeno wrote:
> Hi all,
> I've created a MySQL FeatureSource in Mapguide 2.0 using Mapguide
> Maestro 1.0.9.15910. When I click in the test connection button no
> error is reported, so it seems the connection to MySQL works fine.
> When I try to create a FeatureLayer using the MySQL FeatureSource
> previously defined the following error happens after selecting the
> FeatureSource as resource:
> "Failed to read schema from data source.
> The operation gave the error message: Error en el servidor remoto:
> (559) MgConnectionFailedException.:
> Cannot establish connection.
> Exception occurred in method
> MgServerDescribeSchema::ExecuteDescribeSchema() at line 173 in file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerDescribeSchema.cpp"
> Can anyone help me to solve this problem? (Maybe if you have an
> example of XML LayerDefinition using a MySQL FeatureSource...)
> Thanks in advance
> Manel Gimeno
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090406/84ed599f/attachment.html
