[mapguide-users] Can't create layer using MySQL feature source
Manel Gimeno
manelgimeno at gmail.com
Mon Apr 6 13:15:11 EDT 2009
Thanks Stefan.
I think the main problem is in the connection to MySQL. Even Mapguide Maestro says that there is no error reported I've tried to use the FeatureSource to connect using MapAgent/Test connection and the test doesn't work (it return false).
Could you send me your FeatureSource XML to try to find where the problem is?
Thanks in advance
Manel Gimeno
----- Original Message -----
To: MapGuide Users Mail List
Sent: Monday, April 06, 2009 4:48 PM
Subject: Re: [mapguide-users] Can't create layer using MySQL feature source
Hi Manel,
Here is a layerDefinition that works for me.
Have you specified Coordinate-System-Overrides ?
Stefan Dalakov
<?xml version="1.0" encoding="UTF-8" ?>
- <LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="LayerDefinition-1.1.0.xsd" version="1.1.0">
- <VectorLayerDefinition>
<ResourceId>Library://mysql_ds.FeatureSource</ResourceId>
<FeatureName>Fdotechnop_mg:links</FeatureName>
<FeatureNameType>FeatureClass</FeatureNameType>
- <PropertyMapping>
<Name>LAYER</Name>
<Value>LAYER</Value>
</PropertyMapping>
- <PropertyMapping>
<Name>LENGTH</Name>
<Value>LENGTH</Value>
</PropertyMapping>
<Geometry>ogc_geom</Geometry>
- <VectorScaleRange>
- <PointTypeStyle>
<DisplayAsText>false</DisplayAsText>
<AllowOverpost>false</AllowOverpost>
- <PointRule>
<LegendLabel />
</PointRule>
</PointTypeStyle>
- <LineTypeStyle>
- <LineRule>
<LegendLabel>'Main Pipe'</LegendLabel>
<Filter>"LAYER" = 'Main Pipe'</Filter>
- <LineSymbolization2D>
<LineStyle>Solid</LineStyle>
<Thickness>2</Thickness>
<Color>FF000000</Color>
<Unit>Points</Unit>
<SizeContext>DeviceUnits</SizeContext>
</LineSymbolization2D>
</LineRule>
- <LineRule>
<LegendLabel>'Pipeline'</LegendLabel>
<Filter>"LAYER" = 'Pipeline'</Filter>
<Color>FF000080</Color>
<Unit>Points</Unit>
</LineRule>
- <LineRule>
<LegendLabel />
<Thickness>0.0</Thickness>
<Color>ff000000</Color>
<Unit>Centimeters</Unit>
</LineRule>
</LineTypeStyle>
- <AreaTypeStyle>
- <AreaRule>
<LegendLabel />
- <AreaSymbolization2D>
- <Fill>
<FillPattern>Solid</FillPattern>
<ForegroundColor>ffffffff</ForegroundColor>
<BackgroundColor>ff000000</BackgroundColor>
</Fill>
- <Stroke>
</Stroke>
</AreaSymbolization2D>
</AreaRule>
</AreaTypeStyle>
</VectorScaleRange>
</VectorLayerDefinition>
</LayerDefinition>
Manel Gimeno wrote:
Hi all,
I've created a MySQL FeatureSource in Mapguide 2.0 using Mapguide Maestro 1.0.9.15910. When I click in the test connection button no error is reported, so it seems the connection to MySQL works fine.
When I try to create a FeatureLayer using the MySQL FeatureSource previously defined the following error happens after selecting the FeatureSource as resource:
"Failed to read schema from data source.
The operation gave the error message: Error en el servidor remoto: (559) MgConnectionFailedException.:
Cannot establish connection.
Exception occurred in method MgServerDescribeSchema::ExecuteDescribeSchema() at line 173 in file d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerDescribeSchema.cpp"
Can anyone help me to solve this problem? (Maybe if you have an example of XML LayerDefinition using a MySQL FeatureSource...)
Thanks in advance
Manel Gimeno
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090406/c68530a6/attachment.html
