[mapguide-users] Can't create layer using MySQL feature source
Stefan Dalakov s.dalakov at mapware.net
Mon Apr 6 14:03:06 EDT 2009
Here is the FeatureSource
I find interesting thing here.
When I open this FeatureSource in MG Studio I see
my server name appearing under "Service"
In Maestro the same server name appears under "Database", while "server"
and "port" fields remain empty.
Do you have MG Studio ?
How did your data get in MySQL format ?
If you don't manage, mail me directly, not thru the list and I will send
you the pwd.
Stefan Dalakov
<?xml version="1.0" encoding="utf-8"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
  <Provider>OSGeo.MySQL</Provider>
  <Parameter>
    <Name>Username</Name>
    <Value>%MG_USERNAME%</Value>
  </Parameter>
  <Parameter>
    <Name>Password</Name>
    <Value>%MG_PASSWORD%</Value>
  </Parameter>
  <Parameter>
    <Name>Service</Name>
    <Value>mysql2.winhostingcenter.com</Value>
  </Parameter>
  <Parameter>
    <Name>DataStore</Name>
    <Value>technop_mg</Value>
  </Parameter>
  <SupplementalSpatialContextInfo>
    <Name>Default</Name>
    <CoordinateSystem>LOCAL_CS["Non-Earth (Meter)",LOCAL_DATUM["Local
Datum",0],UNIT["Meter",
1],AXIS["X",EAST],AXIS["Y",NORTH]]</CoordinateSystem>
  </SupplementalSpatialContextInfo>
  <ConfigurationDocument>config.xml</ConfigurationDocument>
</FeatureSource>
Manel Gimeno wrote:
> Thanks Stefan.
> I think the main problem is in the connection to MySQL. Even Mapguide
> Maestro says that there is no error reported I've tried to use the
> FeatureSource  to connect using MapAgent/Test connection and the test
> doesn't work (it return false).
> Could you send me your FeatureSource XML to try to find where the
> problem is?
> Thanks in advance
> Manel Gimeno
> ----- Original Message -----
>     *From:* Stefan Dalakov <mailto:s.dalakov at mapware.net>
>     *To:* MapGuide Users Mail List
>     <mailto:mapguide-users at lists.osgeo.org>
>     *Sent:* Monday, April 06, 2009 4:48 PM
>     *Subject:* Re: [mapguide-users] Can't create layer using MySQL
>     feature source
>     Hi Manel,
>     Here is a layerDefinition that works for me.
>     Have you specified Coordinate-System-Overrides ?
>     Stefan Dalakov
>     <?xml version="1.0" encoding="UTF-8" ?>
>     - <#> <LayerDefinition
>     xmlns:xsi="*http://www.w3.org/2001/XMLSchema-instance*"
>     xsi:noNamespaceSchemaLocation="*LayerDefinition-1.1.0.xsd*"
>     version="*1.1.0*">
>     - <#> <VectorLayerDefinition>
>       <ResourceId>Library://mysql_ds.FeatureSource</ResourceId>
>       <FeatureName>Fdotechnop_mg:links</FeatureName>
>       <FeatureNameType>FeatureClass</FeatureNameType>
>     - <#> <PropertyMapping>
>       <Name>LAYER</Name>
>       <Value>LAYER</Value>
>       </PropertyMapping>
>       <Name>LENGTH</Name>
>       <Value>LENGTH</Value>
>       </PropertyMapping>
>       <Geometry>ogc_geom</Geometry>
>     - <#> <VectorScaleRange>
>     - <#> <PointTypeStyle>
>       <DisplayAsText>false</DisplayAsText>
>       <AllowOverpost>false</AllowOverpost>
>     - <#> <PointRule>
>       <LegendLabel />
>       </PointRule>
>       </PointTypeStyle>
>     - <#> <LineTypeStyle>
>     - <#> <LineRule>
>       <LegendLabel>'Main Pipe'</LegendLabel>
>       <Filter>"LAYER" = 'Main Pipe'</Filter>
>     - <#> <LineSymbolization2D>
>       <LineStyle>Solid</LineStyle>
>       <Thickness>2</Thickness>
>       <Color>FF000000</Color>
>       <Unit>Points</Unit>
>       <SizeContext>DeviceUnits</SizeContext>
>       </LineSymbolization2D>
>       </LineRule>
>     - <#> <LineRule>
>       <LegendLabel>'Pipeline'</LegendLabel>
>       <Filter>"LAYER" = 'Pipeline'</Filter>
>       <Color>FF000080</Color>
>       <Unit>Points</Unit>
>       </LineRule>
>     - <#> <LineRule>
>       <LegendLabel />
>       <Thickness>0.0</Thickness>
>       <Color>ff000000</Color>
>       <Unit>Centimeters</Unit>
>       </LineRule>
>       </LineTypeStyle>
>     - <#> <AreaTypeStyle>
>     - <#> <AreaRule>
>       <LegendLabel />
>     - <#> <AreaSymbolization2D>
>     - <#> <Fill>
>       <FillPattern>Solid</FillPattern>
>       <ForegroundColor>ffffffff</ForegroundColor>
>       <BackgroundColor>ff000000</BackgroundColor>
>       </Fill>
>     - <#> <Stroke>
>       </Stroke>
>       </AreaSymbolization2D>
>       </AreaRule>
>       </AreaTypeStyle>
>       </VectorScaleRange>
>       </VectorLayerDefinition>
>       </LayerDefinition>
>     Manel Gimeno wrote:
>>     Hi all,
>>     I've created a MySQL FeatureSource in Mapguide 2.0 using Mapguide
>>     Maestro 1.0.9.15910. When I click in the test connection button
>>     no error is reported, so it seems the connection to MySQL works fine.
>>     When I try to create a FeatureLayer using the MySQL FeatureSource
>>     previously defined the following error happens after selecting
>>     the FeatureSource as resource:
>>     "Failed to read schema from data source.
>>     The operation gave the error message: Error en el servidor
>>     remoto: (559) MgConnectionFailedException.:
>>     Cannot establish connection.
>>     Exception occurred in method
>>     MgServerDescribeSchema::ExecuteDescribeSchema() at line 173 in
>>     file
>>     d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerDescribeSchema.cpp"
>>     Can anyone help me to solve this problem? (Maybe if you have an
>>     example of XML LayerDefinition using a MySQL FeatureSource...)
>>     Thanks in advance
>>     Manel Gimeno
>>     _______________________________________________
>>     mapguide-users mailing list
>>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
