[mapguide-users] Best method to use dwg files
djonio DJonio at miami-airport.com
Mon Apr 6 20:56:51 EDT 2009
Marty,
Sounds like the position I was in a couple years ago. My focus, however, is on airport campus’ and their facilities but the basics are the basics. So I don’t waste everyones time getting into an unnecessary essay on what I think is the best approach, would you be willing to share what your existing skill set is? .NET? C#? VB? Oracle? ObjectARX.NET?  You mention “program … that will extract/inject all the attribute information to/from a SQL Server database.” What did you use to do this?
r,
dennis
View this message in context: http://n2.nabble.com/Best-method-to-use-dwg-files-tp1813070p2596411.html
