[mapguide-users] Geoserver, WFS and Mapguide
Gary Morin
gary.morin at keynetix.com
Tue Apr 7 12:03:04 EDT 2009
Hi
I've seen the same problem and never managed to get WFS working with
Mapguide although like you I have managed to get geoserver working with
AutoCAD Map.
Someone did indicate that the MapServer WFS may work with MapGuide, so I
about to test that.
Regards
Gary
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dragan
Podvezanec
Sent: 07 April 2009 09:21
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Geoserver, WFS and Mapguide
Hi all,
I have a problem with WFS layers served by Geoserver. I can see layers in
Map 3D 2009, but nothing is shown in MGOS. SRID is ok, 4326, extents of
the map are ok, everything is as it should be, but there is error:
Error: Failed to stylize layer: stat_area_areas
An exception occurred in FDO component.
Schema can not be found in the collection.
StackTrace:
- MgMappingUtil.StylizeLayers line 786 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\m
apping\MappingUtil.cpp Failed to stylize layer: stat_area_areas
I see that this problem has already been reported here
(http://n2.nabble.com/Consuming-WFS%2C-error-in-MGE2009-td2161822.html#a21
61822) , but no one offered a solution that works. Does this mean that
this doesn't work yet?
View this message in context:
http://n2.nabble.com/Geoserver%2C-WFS-and-Mapguide-tp2597650p2597650.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
